Keyless entry Problems RF!! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-31-2007, 08:40 AM Thread Starter
Date registered: Aug 2007
i can only unlock/lock my car when i point my key directly to the infrared eye on the door, the RF has never worked, the remote is set to global for IR and RF like it says in the manual. car is a 2002' C230 Kompressor. is there a fuse for the RF to check? where is the RF reciever? I have just got a new remote from the dealer hoping this would solve the problem, but nothing, any advice or help would be greatly appreciated.
Scott
scottttocs is offline
post #2 of 3 (permalink) Old 09-30-2007, 05:16 PM
mbryant107's Avatar
Date registered: Oct 2006
Vehicle: 2002 C230 Kompressor Coupe
Send a message via AIM to mbryant107 Send a message via Yahoo to mbryant107
Arrow I have the exact same problem!
About a week ago I started getting this problem. My key works when pointed directly at one of the infra red sensors on the door handles, but it's like the FM signal isn't getting through somehow. Also, after the car has set all night, sometimes even the IR sensors won't pick up, but the little light on the key still flashes when I push a button. For that matter, I replaced both of the 2025 batteries in the key itself. I have to pull out the mechanical key, unlock the door, open it, and when all hell breaks loose, stick the electronic key in the ignition to shut it up! Funny thing is, when I've driven the car a few miles, not even enough to warm it up, at least the IR sensors work again, if not the FM.
I had the car in recently and was told by the mechanic that I'm getting low voltage signals all over the car and that the car's battery should be replaced.
Tomorrow, I'm going to do this:
1. Clean battery terminals and check to see if diconnecting/reconnecting terminals resets something in the system.
2. Check voltage on the battery with my multimeter.
3. If the system doesn't reset, I'm going to hook a charger to the battery and see if the additional voltage changes anything.
I can't imagine anything just going out like that one day. I'm hoping it's just a voltage issue.
I'll keep you posted.
Mike >
mbryant107 is offline
post #3 of 3 (permalink) Old 10-03-2007, 11:02 AM
mbryant107's Avatar
Smile
Well, I did all that but to no avail, however, I did find out what my problem was. I found out that the problem was in the key itself. After laying on the counter overnight and being cool to the touch, the IR worked and opened the car. This gave me the idea to put it in the freezer for an hour, and after that, even the radio transmitter worked perfectly. I guess it's just time for a new key.
Hope this helps.
Mike
Keyless Entry srsomasundaram W126 S,SE,SEC,SEL,SD,SDL Class 6 03-29-2007 04:44 PM
keyless entry help benzboy8 W140 S-Class 3 03-24-2006 12:00 PM
Keyless Entry lbc W164 M-Class 3 08-09-2005 12:28 PM
keyless entry problems.... 96S320. W140 S-Class 3 08-06-2004 11:15 AM
Problems with keyless entry? Guest (MBNZ) W203 C-Class 6 04-16-2000 08:09 AM
