Courtesy Light/Sunroof/Mirror Not Working - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-27-2007, 01:39 PM Thread Starter
Date registered: Jul 2007
Vehicle: 2001 E320 4Matic Wagon
Send a message via Yahoo to parrothead
Smile Courtesy Light/Sunroof/Mirror Not Working
In my new (to me) 2001 E320 4Matic wagon, nothing in the area of my courtesy light (mirror, sunroof) is working with the exception of the red "SOS" button lighting up. I have checked the bulbs in the courtesy light, as well as all the fuses in the fuse box on the left side of the dash (door open). Also just discovered the auto-windows-down/auto-sunroof-open feature with the key fob and while it does open the windows, the sunroof still doesn't budge.
Is there another fuse or relay or even a known issue with a wiring harness connector that could be causing all these things to not work?? The courtesy lights in the bottom of the front doors and those in the back work fine.
Thanks!!
glen
parrothead is offline
post #2 of 2 (permalink) Old 08-28-2007, 04:13 PM
ctbenztech's Avatar
Date registered: Aug 2007
Vehicle: ml430
sounds like your having problems with you overhead control pannel.
there a common problem. there just a plug and play item. you can find them on ebay. junk yard. if you know someone with the same car diagnoses is easy
just swap them over at test your functions. they come out by prying between
unit and head linner. right where the sun roof is.
ctbenztech is offline
Vito Courtesy light harness LCN V-Class 2 02-09-2007 02:55 PM
Light by sunroof not working RDM3 W201 190-Class 14 06-16-2006 11:02 AM
Trouble with Electronics C320 - Sunroof, Singal light, mirror backround lights etc. RaehZa W203 C-Class 0 04-07-2006 08:27 PM
Wierd courtesy light problems danwatt W126 S,SE,SEC,SEL,SD,SDL Class 12 06-23-2005 10:41 PM
Replace courtesy light jbanks15 R170 SLK-Class 0 09-05-2002 03:05 AM
