Engine leakage,need some info - Page 2 - Mercedes-Benz Forum
post #11 of 33 (permalink) Old 08-23-2007, 08:50 PM Thread Starter
alexus.one's Avatar
Date registered: Jun 2007
Vehicle: C280 '97, SLK55 BRABUS AMG '05
Quoted: 2 Post(s)
um, I thought dealers dont do that, thats why i went to dealer so they tell me more acurate info.
What dealer did they paced die every where and told me to come back after 500 miiles.
THe engine does have visual leakage on right passanger side. but its only "wet", when i move the car from parkong there are no oil on the road.
alexus.one is offline
post #12 of 33 (permalink) Old 08-24-2007, 12:39 AM
Date registered: Nov 2006
Vehicle: Oo == oO 98 E320
Is the car even leaking enough to warrant a repair of any sort?
'87 300E: sold after 11years @ 230k & still on the road somewhere in rural Tennessee.
'94 C220 with 93k totalled 10/06 by hit & run broadsiding monster truck: not a scratch or bruise for me
johnamoss is offline
post #13 of 33 (permalink) Old 08-24-2007, 09:46 AM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
it is leaking, but how serious i dont know
i went to one show they even didnt see the leaks (al can see the engine side is oiled)
went to enother they told "thats ok , all merces are leaking"
and delaer told that leaks are severe
post #14 of 33 (permalink) Old 08-24-2007, 10:39 AM
Kajtek1's Avatar
Quoted: 1168 Post(s)
If there are no oil stains on the driveway, it can't be serious. If you are DIY alexus, wash the engine well, remove bottom shield if it is on the way and observe. I wouldn't worry about sweating.
The only MB I couldn't make totally dry was 1983 300 D. I fixed about 8 leaks on it, but some small drip under the turbo was hard to pinpoint. The 320 engines have tendency to leaks on the passenger side under engine breather, but that is minimal problem.
Kajtek1 is offline
post #15 of 33 (permalink) Old 08-24-2007, 10:51 AM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
ok then i levae this engine things for now... if that it is not that citical..
Now, im more consorn with my tahometer not working
post #16 of 33 (permalink) Old 08-25-2007, 02:07 AM
[QUOTE=alexus.one]it is leaking, but how serious i dont know
Just be sure you check your oil at least weekly or every time you get gas. Suddenly running too low is usually the final last straw for an engine.
post #17 of 33 (permalink) Old 08-25-2007, 09:37 AM
ctbenztech's Avatar
Date registered: Aug 2007
Vehicle: ml430
dontlistin to this idoit. hes fuckin stupid. if you have little money then have the dealer do right the first time. trust you will end up doing it again if you have a independent shop do it.
ctbenztech is offline
post #18 of 33 (permalink) Old 08-25-2007, 09:45 AM
Kajtek1's Avatar
[QUOTE=johnamoss]
Than some might want to know, that Mercedes engines are not only equipped with no oil pressure alarm, that displays in red, but also with low oil waring, that displays in yellow and gives you plenty of time to drive home and add some oil.
Unless you have a hole in the block and the red alarm will follow yellow warning in the matter of seconds.
Kajtek1 is offline
post #19 of 33 (permalink) Old 08-25-2007, 09:45 AM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
the last one is very friendly...
dude if i let the dealer do all the things in my car then i would spend like $40,000
Then it maybe be better to get this year model
post #20 of 33 (permalink) Old 08-25-2007, 09:48 AM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
oh nice i didnt know it has low oil alarm, i hope it works
Thanks for info!
    Need info about M119 engine. zoom zoom General Mercedes-Benz 9 02-16-2008 11:45 PM
    Need info for the best engine oil for W210 zainal9977 W210 E-Class 13 01-29-2008 09:25 PM
    Engine info Hoosierdaddy W126 S,SE,SEC,SEL,SD,SDL Class 1 04-26-2006 06:36 AM
    AMG info and the 6.3 engine dsb R171 SLK-Class 1 01-12-2006 09:13 AM
    engine swap info?? euro engine in US car running rich HeirKranz W126 S,SE,SEC,SEL,SD,SDL Class 14 04-28-2005 07:18 AM
