REMOVING 01 C320 GLOVE BOX - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-18-2007, 08:30 AM Thread Starter
Date registered: Aug 2007
hello all... i've got a clicking in my dash whenever i turn my car on, and after removing the panel underneath the dash on the passenger side (usa) i found that it was coming from a sort of actuator having something to do with the air conditioning and heat. i'm attempting to remove the glove box to repair and replace this part, but i can't seem to get the glove box assembly out... i removed all of the bolts from it, but it is still attatched to the center console... can someone PLEASE help me as i'm trying to sell this car, and this is the only thing i need to do for it to be back to perfect condition?????? thanks in advance, and I searched also..
buymybenz is offline
post #2 of 6 (permalink) Old 08-18-2007, 04:53 PM
Date registered: Mar 2004
Vehicle: W203 modified
Send a message via MSN to miroj Send a message via Skype™ to miroj
- remove centre console
- remove radio
- remove trim between glovebox and radio
- remove glovebox (dont forget the vertical screws inside the glovebox)
Modz ... enjoy the difference. www.benzmodz.com
miroj is offline
post #3 of 6 (permalink) Old 08-18-2007, 05:49 PM
ctbenztech's Avatar
Vehicle: ml430
they are the foot well flap linkages
they are not behind the glove box you will not get both of them
this is not an easy jb for a beginner. im a seasoned tech and i do them in about
1 1/2 hours. it takes removing center console radio and trim center vents
headlight switch, dash under steering wheel( the part with the ignition switch is in)so the eis has to ccome out to. thers alot more and if you dont know what your doing it can get messy putting it back together. instuctions call for removing the whole dash. i would take it to the dealer just my 2 cents. i can walk you through it more detailed just pm me
ctbenztech is offline
post #4 of 6 (permalink) Old 08-19-2007, 03:13 AM
I guess it depends exactly which vent it is. Generally removing the whole dashboard is the best way.
miroj is offline
post #5 of 6 (permalink) Old 08-19-2007, 08:04 AM
ctbenztech's Avatar
Vehicle: ml430
they aree probly both broken 9 outa 10 times they are both broken or just the left side. i have never just changed the right side. unless someone did the left and never changed the right.
post #6 of 6 (permalink) Old 08-19-2007, 06:21 PM
I think you are right. it sounds like the footwell flaps in which case removing the glovebox does nothing.
miroj is offline
    glove box vinnyz R171 SLK-Class 38 11-03-2012 04:47 PM
    Removing wood trim from glove box lid Nardo W123 E,CE,D,CD,TD,TE Class 12 01-18-2007 05:52 AM
    Glove box Mike K W211 E-Class 3 01-11-2007 07:27 AM
    Glove box Mike K W211 E-Class 0 05-23-2006 01:09 PM
    Seeking oddments box, glove box alternative kborglum For Sale/Wanted/Trade/Giveaway 0 04-12-2006 08:31 PM
