1999 ML320 BAS/ESP Check Engine after taking Steep "L" shaped Exit Ramp - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 08-18-2007, 08:54 AM Thread Starter
Date registered: Aug 2007
Vehicle: 2007 Mercedes-Benz ML350
Exclamation 1999 ML320 BAS/ESP Check Engine after taking Steep "L" shaped Exit Ramp
I purchased a 1999 ML320 recently which has low miles - only 46,000 miles. The current problem is puzzling. For everday driving on local roads no problems. Highway driving no problems. However, when we take this one exit ("L" shaped exit ramp) off the highway which slopes down and to the right and then we are downtown faced with several city blocks of traffic lights. Consistenly, every time, after taking this exit and going maybe a block or two, The dashboard gauges light up like a christmas tree. The BAS/ESP, Check Engine, Brake lights all come on and then the transmission only allows us to use the low gear to drive. After waiting a couple of minutes, turning the car off and then restarting the lights go out and the ML drives normally again. The Check Engine stays on, but eventually goes out after several restarts of the engine. Since purchasing this vehicle, I have replaced the brake pads back/front, front brake discs, MAS, vibration damper, transmission electrical plate, battery, rear crank seal, motor mounts, upper oil pan seal and of course not to mention labor. My mechanic is sending his kids through school off this vehicle repair. Any help would be appreciated. Thanks.
jurga is offline
post #2 of 10 (permalink) Old 08-18-2007, 03:26 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
Get the codes read and post them. Advance Auto or Autozone will do it for free.
Mike
Michael Pillay is offline
post #3 of 10 (permalink) Old 08-18-2007, 03:44 PM
johnhef's Avatar
Date registered: Mar 2007
Vehicle: Too Many
Send a message via AIM to johnhef
just a guess from your description: lateral accelleration sensor, located under the center console.
Master Certified 10 years MB tech
1980 500SE Euro
1981 500SEL Euro
1982 380SEL
1983 500SEC Euro
1983 300TD
1984 500SEC - parts car
1984 300TD Euro
1985 190E 2.3-16 Euro
1986 190E 2.3-16
1986 190E 2.3-16 Lemons
1987 300D
1999 C230K
2003 C320T-4
2003 E55
johnhef is offline
post #4 of 10 (permalink) Old 08-18-2007, 07:29 PM
joshuajeeper's Avatar
Date registered: Sep 2006
Vehicle: 1985 Mercedes 300TD, 2014 GLK250 Bluetec
By any chance, do you pass a radio station or military facility or power station/plant? Weird interferences have been know to cause complaints like this.
1985 300TD - "Panzer Wagen" - undergoing full restoration (resto - mod)
2014 GLK250 Bluetec (Wife's Car)
Mercedes-Benz Master Certified Technician.
http://www.flickr.com/photos/joshuajeeper/
joshuajeeper is offline
post #5 of 10 (permalink) Old 08-18-2007, 11:50 PM
Date registered: Aug 2006
Vehicle: 97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
Quoted: 223 Post(s)
Twice it happened to my 01 320 (BAS/ESP light turned on). In both cases it was a defective stop light switch.
edcarls is offline
post #6 of 10 (permalink) Old 08-20-2007, 08:33 AM
johnhef's Avatar
Vehicle: Too Many
it could be the stop light switch but I'd expect it to do it much more often if it was. Why the car goes into limp home is a little odd though.
1980 500SE Euro
1981 500SEL Euro
1982 380SEL
1983 500SEC Euro
1983 300TD
1984 300TD Euro
1986 190E 2.3-16
1987 300D
1999 C230K
2003 C320T-4
2003 E55
johnhef is offline
post #7 of 10 (permalink) Old 08-20-2007, 08:12 PM Thread Starter
I am going to get our mechanic to look at it one more time and focus on the aceleration sensor.
jurga is offline
post #8 of 10 (permalink) Old 08-23-2007, 03:08 PM Thread Starter
I finally got the codes:
ETC - 132,134,135,136,137 - all stored
ME2-SFI - P0720,P00700-106 - Not Defined
ESP - C1022(CAN Fault Control Unit w/ME-SFI),C1024(CAN Fault Control Unit ETC) - Stored
ESP - C1032(CAN Fault Control Unit Inst. Clust),C1030(CAN Fault Control Unit Transf Case) - Stored
AAM -
ICM - B1040(CAN Fault Control Unit MR engine control) stored
ICM - B1041(CAN Fault Control Unit Traction Systems) - stored
ICM - B1089(CAN FAult Control Unit Transfer Case) - stored
The mechanic drove it to the same exit ramp and got the same codes. He brought his laptop to read the codes. THe ML320 acted the same way when it exited from another steep ramp which curved to the right. He then cleared all of the codes and then drove a short distance before getting another set of codes. It only appears to happen in this area.....nowhere else. Could there be a latent electrical capacitance built up and not discharged yet from the lateral acelerator sensor ? He feels it might be the ESP Control Module
jurga is offline
post #9 of 10 (permalink) Old 08-27-2007, 12:31 PM Thread Starter
Angry Only happens in certain part of downtown - hills or level ground - does not matter
An update........My wife just called and said that she bipassed the exit ramp and is in an area of downtown near the exit ramp on a flat surface road where we believe there is an area with a ton of radio/tv/satellite frequency in the area and as usual, the dashboard lit up like a christmas tree.....I am talking to her as we speak. We now definitely believe it has something to do with a magenetic/electrical surge because of the intense radio/tv/satellite frequency in the area.
jurga is offline
post #10 of 10 (permalink) Old 08-27-2007, 12:46 PM
johnhef's Avatar
Vehicle: Too Many
find another owner maybe though the mechanic with a similar vehicle and drive it though the same area and see what happens?
1980 500SE Euro
1981 500SEL Euro
1982 380SEL
1983 500SEC Euro
1983 300TD
1984 300TD Euro
1986 190E 2.3-16
1987 300D
1999 C230K
2003 C320T-4
2003 E55
johnhef is offline
    BAS ESP and Check Engine Lights On dominic888 W163 M-Class 14 01-13-2009 08:12 AM
    Rolling backwards while on "D" on steep incline ProvingGrounds W140 S-Class 12 11-08-2006 12:56 PM
    Dealer found cause of my "BAS/ESP" light coming on, and its not the brake lamp switch... S4toML W163 M-Class 7 07-14-2003 05:58 PM
    Follow up on BAS/ESP/ABS lights and "B" service. Chris Krikorian W163 M-Class 0 10-25-2002 04:29 PM
