2003 SL500 Stuck in Park - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 12-25-2007, 11:05 PM
Chicky's Avatar
Date registered: Apr 2007
Vehicle: 1991 R129 500SL
Quoted: 58 Post(s)
Hi and welcome to BW, you may also try posting at the R230 forum and get more detailed technical answer to your problem.
Goodluck
Chicky is offline
post #12 of 15 (permalink) Old 12-30-2007, 07:05 AM
Date registered: Dec 2007
Thanks StreetGlower, Got the car back yesterday. Just like new... 800.00 bucks later. It was still under factory warranty! I would not be caught dead without a warranty on this car.
mike12079 is offline
post #13 of 15 (permalink) Old 12-30-2007, 08:03 AM
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 4 Post(s)
I have a similar problem with my CLK. Oddly, I can move the shifter into P R N & D with no problem and the car runs through the gear changes as normal but I cannot access 1st 2nd 3rd or 4th. It's as if someone welded a steel bar in the shifter.
ThrillKill is offline
post #14 of 15 (permalink) Old 01-29-2009, 05:15 AM
Date registered: Jan 2009
You can replace your broken gear selector lever with a new one from Home | Monoglobal. Fitting instructions included. No VIN coding required.
monoglobal is offline
post #15 of 15 (permalink) Old 02-02-2009, 08:34 PM
RoadsideDude's Avatar
Date registered: Mar 2008
Vehicle: 2008 R350
yeah, unfortunately on the 230 chassis and 220, you have to hammer the end of the shifter handle, (AFTER CAREFULLY REMOVING THE SHIFTER KNOB PEOPLE) to get them out of park when the shifter does go bad; common problem on these cars, everything else has a D hole release or a button under the shifter, as on the 211; the last 230 chassis I had with a bad shifter, I jacked it up and removed the shifter linkage keeper key, not very easy to remove, but saves you from having to drag the car out of the clients garage, leaving nice long skid marks on his new driveway, while hes standing there wanting to rough you up, because you're the guy hes mad at right now; not the wrecker driver, hes grinning, as the car squeals its way up the rollback bed, thanks for listening, Take care, Ron
RoadsideDude is offline
    Help--stuck in park bobbypoz C208/A208 CLK-Class 1 08-14-2007 12:48 PM
    Help--stuck in park bobbypoz General Mercedes-Benz 2 08-14-2007 09:44 AM
    Help--stuck in park bobbypoz C208/A208 CLK-Class 0 08-13-2007 09:59 PM
    Stuck in Park STL-Benz W163 M-Class 2 08-15-2006 06:45 PM
    Stuck in Park mn117n W163 M-Class 1 09-18-2004 12:06 PM
