2007 Paint Quality...Poor - Page 2 - Mercedes-Benz Forum
post #11 of 24 (permalink) Old 08-19-2007, 08:16 PM
B-McD's Avatar
Date registered: Aug 2005
Vehicle: '79 450 SLC
Send a message via MSN to B-McD
Well after all these posts no ones really managed to say why the new cars have this problem. From what I've heard, and the most reasonable answer, is that the new paints have to be more "environmentally friendly" and the down side to this is the fact that they dont cure the same way as the old and end up having slight orange peel look. And i don't think MB will be able to buff every car before a clear coat without a considerable extra cost.
B-McD is offline
post #12 of 24 (permalink) Old 08-22-2007, 11:36 PM
Date registered: Feb 2007
could someone be kind enough to explain what this "orange peal" look means?
Also, the clear coat disappears in 6 months or so right? So you could buff the paint and then wax it and get rid of this "orange peal" problem?
vik888 is offline
post #13 of 24 (permalink) Old 08-23-2007, 12:31 AM
Date registered: Feb 2006
Vehicle: 1999 ML320
Quoted: 311 Post(s)
Originally Posted by Jayhawk
If the paint is as bad as you say--and it is ubiquitous--MB will soon issue a recall and you and the others should have the option of a complete make-over or a new car. They don't let real problem fester. They've learned the hard way it does not pay to ignore real problems...
Your must be joking.
MB will not even pay for a frigging 10$ design problem.
How is the color issue a "real problem" ? Transmission failure is a real problem. Power steering blowup is a real problem.
mlfun is offline
post #14 of 24 (permalink) Old 08-23-2007, 07:16 AM
asianml's Avatar
Date registered: Sep 2005
It may or may not be on your car, but look at the paint very closely, like on the trunk where the badges are and look around it. It may be hard to see at first, but if your car has orange peel, then it should resemble the peel of a orange (lol).
You can see it slightly in this picture along the fender. It's not as noticeable on lighter colors. Look at the reflections of objects in the paint to see the orange peel.
You can definitely notice it beneath the ML320 badge here.
But, a good wax and polish will do well to hide most of it making it look smooth.
asianml is offline
post #15 of 24 (permalink) Old 08-23-2007, 09:08 AM
slybydesign's Avatar
Date registered: Jan 2007
Vehicle: My Two Left Feet
Clear Coat should never disappear in Six Monnths, you must be thinking of a Wax job which should be done every six months.
If im not mistaken, and correct me if Im wrong, but Orange peal is something that happens to the Clear Coat and not the paint it self. I could be wrong.
I have corrected this effect along with fish eye, by wet sanding (with a huge amount of research in the correct way of wet sanding) my car with 110% results and it cost me nothing but time. I was then able to do a very strengent claying and waxing and the car is still smooth.
Yes, they should have taken care of that at the dealer, but I will say this, my dealer offered to fully detail my car prior to purchase and I told him no....leave the car alone. I knew I would detail it my self.
OK after a quick search I found Orange Peal is something that accures during the painting process. I thought is was something that accurd to the clear coat. In any event, a realy realy realy good detail shop should be able to take care of that, good look.
3. Paul Hamm, Gymnast: I owe a lot to my parents, especially my mother and father.
slybydesign is offline
post #16 of 24 (permalink) Old 08-23-2007, 09:25 AM
Jayhawk's Avatar
Vehicle: S500/W220/2000
Here is a link to a rather extreme example of orange peel (fourth photo down)...
OT: Short photo lesson - Autopia Car Detailing Forum
Don't believe everything you think
Jayhawk is offline
post #17 of 24 (permalink) Old 08-23-2007, 09:27 AM
Vehicle: Several MB's
Originally Posted by Emergencydpt
I have a 2007 CLS550 and I have to say it has the absolute worst quality paint of any car I've owned. My Honda Element with painted plastic fenders looks 10 times better.
I've heard the tale about the new water soluable paint but orange peal is orange peal and it has to be buffed out before you clear coat. A step obviously skipped on this $76,000 car.
Dissapointed.
I have owned MB cars for close to 40 years now and one thing that has been common with them is that the paint has orange peel most predominantly on the sides. I recently parted with a 1991 560SEL with the older less friendly paint and sure enough the paint had orange peel. Unfortunately that is the way it is.
Someone here recommended wet sanding the car. That is a possibility but in my opinion you would be crazy to do that.
Lou K
Several And various Autos
Lou K is offline
post #18 of 24 (permalink) Old 08-23-2007, 09:28 AM
Designo_E320
Guest
Posts: n/a
Quoted: Post(s)
I may be going out on a limb here but didn't they try to put a thicker layer of paint towards the bottom of the car to protect it from stone chips? If they did then this may explain the orange peel due to presence of much thicker paint. The only time I see "orange-peel" is when it is asociated with an inverted nipple on women's breasts which is extremely sad for me because then I have to give them the bad new that they have advanced breast cancer that most likely has already spread.
On the other hand if the banana peel exists on the bottom of the car for the purposes that I have described above then I believe that I could live with that.
Have a great day!
post #19 of 24 (permalink) Old 08-23-2007, 09:38 AM
Jayhawk's Avatar
I think that is the only effective way to deal w/ OP. I had to have mine wet sanded and re-clear-coated, but it looks perfect now.
Jayhawk is offline
post #20 of 24 (permalink) Old 08-23-2007, 11:02 AM
So how long should the clear coat last?
vik888 is offline
    poor speakerphone quality ic2000 R171 SLK-Class 23 05-25-2005 01:58 AM
    Poor quality 2005 command mark11 Audio & Telematics Forum 7 01-27-2005 11:46 AM
    Poor Quality Chuck V Off-Topic 3 04-13-2004 10:10 PM
    Poor quality car Panazonic Off-Topic 4 02-02-2004 08:50 PM
    Owners with Designo: Is the paint quality on your cars better than standard MB paint? Qui R170 SLK-Class 4 04-30-2002 10:55 PM
