Help--stuck in park - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-13-2007, 10:04 PM Thread Starter
Date registered: Aug 2007
Help--stuck in park
I was driving today from Minnesota to Chicago and spilled a small portion of water on my console. Immediately thereafter the several lights came on and the ESP (??) light stayed lite in the left corner. When I pulled off the expressway several hours later I noticed that I had very poor acceleration but I was able to get home. When I pulled into the garage I couldn''t get the car to reverse. I moved it to park and it was then stuck.
I called road side assistance and they told me to insert a pen into the hole near the shifting stick and after playing with it I was able to get the car out of park and shift the gears.
There are now no error messages on the dashboard. My question is has the problem fixed itself or do I need to take it to the dealer who will probably tell me it needs to be fixed even if it doesn't.
bobbypoz is offline
post #2 of 3 (permalink) Old 08-14-2007, 01:41 AM
shrimpton's Avatar
Vehicle: '90 560SEL, V8 Landcruiser, Toyota S/Wagon
Wear a bib next time you drink and drive, or drink from a bottle with a non drip teat...
Just kidding!.
Hopefully natural evaporation has sorted your problem - good luck!.
shrimpton is offline
post #3 of 3 (permalink) Old 08-14-2007, 09:44 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Bob.
I'm glad you got home okay; liquid in the console is a bad deal on late-model MB cars.
As a precaution I'd probably pull the console cover and run a blow dryer on low heat in there, and then probably disconnect the battery and reconnect it to clear any codes and let things reset. Be sure your owners manual is handy as you'll need to manually reset the windows and you may need the radio code.
If the problem stays gone, say a prayer of thanks and count your blessings.
Take care and enjoy the ride,
Check Codes is offline
    Help--stuck in park bobbypoz C208/A208 CLK-Class 0 08-13-2007 09:59 PM
    Stuck in park Andrzejek W202 C-Class 1 12-15-2006 02:07 PM
    Stuck in Park STL-Benz W163 M-Class 2 08-15-2006 06:45 PM
    Stuck in Park!!!! ByByeAmericanPie W163 M-Class 10 12-06-2005 01:15 PM
    Stuck in Park mn117n W163 M-Class 1 09-18-2004 12:06 PM
