Petrol / Gas for my MB - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-12-2007, 03:18 PM Thread Starter
Date registered: Aug 2007
I just bought a CE 230 and it says that the car should have super lead free 98 octane fuel. But in the manual it says you can change to normal 95 lead free is you switch the EZ-KAT switch to N instead of S, which I have done, but what effect will it have besides saving me 20 cents a litre (Norwegian gas prices are $ 2 USD for 1 litre).
RaezoR is offline
post #2 of 4 (permalink) Old 08-13-2007, 12:38 PM
Musikmann's Avatar
Quoted: 5 Post(s)
Congratulations on your Mercedes!
If the manual says 95 octane lead free gasoline is okay with the N switch activated, I doubt you will notice any significant difference. A lot of people have asked about using gasoline with a less-than-recommeded octane rating, and that is a definite no-no.
Musikmann is offline
post #3 of 4 (permalink) Old 08-13-2007, 09:47 PM
Diesel Benz's Avatar
Quoted: 32 Post(s)
At least it should be completely safe to drive with 95 octane gasoline in this case. I believe the noticeable difference (if any) would be minor increase of gas consumption and minor decrease of max engine power. I would assume the difference being so small that it would be difficult to observe.
Diesel Benz is offline
post #4 of 4 (permalink) Old 08-14-2007, 09:47 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, raezor.
Setting the switch tells the ECU to restrict certain parameters to accommodate the lower octane. So you're not doing any damage to the engine or fuel system.
You will probably notice a small decrease in fuel economy, although unless you're a true performance driver you won't notice any loss of power. I'd watch the economy issue and if it's significant enough, it may be more cost-effective in the long run to buy the more expensive fuel.
Take care and enjoy the ride,
Check Codes is offline
    URGENT Wagon Gas/Petrol Tank Q silver50 W124 E,CE,D,TD Class 6 03-14-2007 12:00 PM
    Petrol (gas) smell inside the car 420 SE W126 S,SE,SEC,SEL,SD,SDL Class 17 12-04-2005 12:38 PM
    Go further on less petrol?! arran_watson W126 S,SE,SEC,SEL,SD,SDL Class 15 10-25-2005 05:16 AM
    How much are you paying for " Gas " or " Petrol" in your Country? Uandjack R170 SLK-Class 27 08-07-2004 07:27 PM
    oil (gas/petrol) filter replacement tim hk W124 E,CE,D,TD Class 0 01-19-2004 02:25 AM
