How to clean wheels from carbon dust? - Page 3 - Mercedes-Benz Forum
post #21 of 46 (permalink) Old 08-11-2007, 11:00 AM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Originally Posted by alexus.one
ok well im gonna get a bit of topic here... you know that incert in the middle of the wheel, its made og fiberglass or some sort of plastic. The paint brusted off. So maybe some on knows how I can take ot out, so i can paint it?
Tnx
You may have to take your wheel off to pop it off from behind. Don't bother painting it, you should be able to get a new one for about $10--or free if you look around.
Don't believe everything you think
Jayhawk is offline
post #22 of 46 (permalink) Old 08-11-2007, 11:02 AM Thread Starter
alexus.one's Avatar
Date registered: Jun 2007
Vehicle: C280 '97, SLK55 BRABUS AMG '05
Quoted: 2 Post(s)
uhh, can I take it off without removing the wheel?
Also how that thing actually called?
And where can I get it for free? Junk yard?
alexus.one is offline
post #23 of 46 (permalink) Old 08-11-2007, 11:34 AM
Jayhawk's Avatar
If you can't get a screwdriver behind it to pop it off from the front you may have to remove the wheel to punch it out from behind.
They are called wheel center caps.
Those caps are usually available at wheel and tire places, at your dealers, and/or at junk yards. Here are some places to get them online:
Results for wheel center caps From Performance Products
CenterCap.net
Mercedes Hubcaps, Wheel covers, Used hub caps, Hubcap and Mercedes Center caps - Hubcaps.com
Jayhawk is offline
post #24 of 46 (permalink) Old 08-11-2007, 11:51 AM
MB300EUK's Avatar
Date registered: Jul 2007
CLEAN WHEELS
in the uk we have something called "TRAFIC FILM REMOVER"
commonly refered to as TFR.
not a very pleasent chemical composision but reliable all the same,
and does what it says on the tin, has allways done the job for me.
also saves a fourtune on expensive wheel specific products.
but be warned IT IS NASTY STUFF. but then again thats proberly why it works.
good luck......
MB300EUK is offline
post #25 of 46 (permalink) Old 08-11-2007, 04:34 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
You can try to pop it up with small screwdriver, but that will leave small marks on it even if you are lucky not breaking one of the clips behind it.
Trust me on this one -take the wheel off. I have repainted mine several times. E class has the plastic cheaply painted and the main problem is to remove the old paint so it doesn't flake anymore.
Kajtek1 is offline
post #26 of 46 (permalink) Old 08-11-2007, 04:58 PM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
Agree with kajtek just take the wheel off and pop thae plastic cap behind to be safe and don't forget to torque the lug bolts after.
-JOE55
JOE55 is offline
post #27 of 46 (permalink) Old 08-11-2007, 05:07 PM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
well it will cost me some $$$ to make the shop to take the whell off
post #28 of 46 (permalink) Old 08-11-2007, 11:32 PM
Vehicle: CLK 220CDi
Let me apologise on behalf of everyone here, it was not clear from your earlier posts that you have some kind of disability. (allthough some of the spelling should have been a clue)
Are you honestly saying you cannot take a wheel off by yourself?
Russ
CLK220CDi
Avantgarde
rf065 is offline
post #29 of 46 (permalink) Old 08-12-2007, 12:28 AM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
i dont have car shop, and the wheel was mounted with pneumatic screw/bolt driver, i was trying to take the wheel off with standard X type key and i just couldnt do it. bolts didnt move... also even If I take it of, I probably wouldnt be able to screw balts back as good as pneumatic machine can do... and thats my safty...
and just in case, im a programer and electrinics engeneer not mechanic, i can use power tools but its not that i use every day
post #30 of 46 (permalink) Old 08-12-2007, 01:09 AM
Vehicle: CLK 220CDi
It sounds as though whoever last put your wheel on, put it on too tight. If you know who it was, take it back to them and tell them to undo the bolts and tighten them to the correct torque.
A pneumatic gun only makes the job quicker and easier, it cannot do a better job than you could do yourself, especially if the operator does not use a torque wrench to check the bolts are at the correct torque.
Putting bolts on too tight can strip the threads or break the studs, and that is not good for your safety either.
Russ
CLK220CDi
Avantgarde
rf065 is offline
    How to clean carbon deposit off exhaust tips? jerryxu R170 SLK-Class 17 07-31-2007 03:34 PM
    Protect wheels from brake dust rickpaguyo The Discount Tire Direct Tire, Wheel, Brake & Suspension 6 11-01-2006 09:50 AM
    Excellent way to clean dust from within small crevices on radio and other dash parts!!! Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 4 08-10-2004 05:14 AM
    If you are new to M-B (E55) and L-O-V-E the brake dust on your wheels... HarleyB W211 E55 AMG, E63 AMG 5 11-10-2003 12:37 PM
    Dust Covers for Front Wheels Pickle78664 R170 SLK-Class 16 09-27-2003 02:29 PM
