timing chain replacement - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-07-2007, 09:59 PM Thread Starter
Date registered: Aug 2007
Vehicle: 190 E
Post timing chain replacement
I have an 84 190e 4 cylinder. timing chain is on its last mile.
other than the obvious(timing chain)can any one write me a list of other parts I should be replacing on this operation. Gaskets, pins, springs, bearings, glide rails, and such.
I cant find a kit and I only want to do it once.
Rodrigo is offline
post #2 of 3 (permalink) Old 08-07-2007, 10:09 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 695 Post(s)
Chain, chain guides, chain tensioner, f crank seal.
GeeS is offline
post #3 of 3 (permalink) Old 08-07-2007, 10:17 PM Thread Starter
Vehicle: 190 E
thanx Ron
Rodrigo is offline
    Timing chain Replacement sklas W126 S,SE,SEC,SEL,SD,SDL Class 15 06-22-2004 04:59 PM
    Timing chain replacement DREIZACK W126 S,SE,SEC,SEL,SD,SDL Class 4 06-20-2004 11:15 PM
    Timing chain replacement Hipine G-Class 9 05-07-2004 10:37 AM
    Timing chain replacement/timing issue 1990 420SEL supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-09-2003 03:03 PM
    Timing Chain replacement tbl01 W123 E,CE,D,CD,TD,TE Class 0 03-01-2003 06:14 AM
