EC light is on and won't turn off (a/c not cold) - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-07-2007, 05:27 PM Thread Starter
Date registered: Aug 2007
Vehicle: 2000 E320 4MATIC
EC light is on and won't turn off (a/c not cold) FOR 2000E-320 4MATIC
I was playing AROUND WITH THE BUTTONS WHILE THE KEY WAS IN POSITION 2. NO COLD A/C SINCE THEN. HELP!!! I'M HOT!
henbotch is offline
post #2 of 7 (permalink) Old 08-07-2007, 06:17 PM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
Welcome to the Forum henbotch!
Sorry to hear about your AC acting wierd you might wanna check this post regarding your AC problem:
http://www.benzworld.org/forums/w210...-cold-air.html
Btw, please complete your PROFILE - Vehicle & Location when you have a minute.
Thanks,
-JOE55
JOE55 is offline
post #3 of 7 (permalink) Old 08-08-2007, 05:04 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
The light indicates that the compressor is not operating, it can be due to low charge or a defective sensor.
Peter Guenther is offline
post #4 of 7 (permalink) Old 08-08-2007, 08:13 AM
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
add some A/C booster from autozone right quick and see if that solves the problem...if you don't know wheree the A/C inlet is, have a mechanic show you, it's free. if youe EC doesn't go offf you might have to have a system check to locate the problem. they have to pull your codes too. good luck.
benz rider is offline
post #5 of 7 (permalink) Old 08-08-2007, 12:51 PM Thread Starter
Thank You. My profile is updated.
henbotch is offline
post #6 of 7 (permalink) Old 08-08-2007, 12:52 PM Thread Starter
My car is with a mechanic. He says that I may have turned off one of my sensosrs. I'll give an update with the $$damage report later.
henbotch is offline
post #7 of 7 (permalink) Old 08-09-2007, 06:20 PM
ctbenztech's Avatar
Vehicle: ml430
the ec light can be on for a couple reasons
1. pressure to low...repair..charge ac
2.pressure sensor if fualty
3.acc control modual needs to be programed to turn off low pressure cut off switch. ask dealer about it. its an update that anyone with a SDS computer
can do
ctbenztech is offline
    Xenon light didn't turn off by them self? Thierry2000clk C208/A208 CLK-Class 9 01-23-2007 12:27 PM
    US Turn-Light-Lenses Guest (MBNZ) W124 E,CE,D,TD Class 12 09-19-2006 10:43 PM
    Fog light won't turn off (help) mdenman W163 M-Class 2 05-31-2006 09:59 PM
    How to turn off the light in the trunk s4200 W140 S-Class 5 02-10-2006 04:18 PM
    turn off oil light theboss W126 S,SE,SEC,SEL,SD,SDL Class 3 05-31-2005 07:09 AM
