an yellow brake indicator in the instrument cluster is blinking .what does it mean? - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 08-07-2007, 12:29 AM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
Originally Posted by rickyeby
i dont have an owners manual with me so i was confused what it was.
You might wanna check this out - buy it now for $3.33 only.
eBay Motors: 1994 MERCEDES C220 C280 E320 DIY REPAIR & SERVICE GUIDE (item 290146527346 end time Aug-08-07 02:19:14 PDT)
JOE55 is offline
post #12 of 14 (permalink) Old 08-07-2007, 11:43 AM
Date registered: Aug 2006
Vehicle: 97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
Quoted: 222 Post(s)
Originally Posted by CalifSLK
There are really no electrical pad sensors today. Likelyhood is that you are low on fluid. With that said, low fluid can be due to worn out pads.
Yes, CalifSLK, there are electrical pad sensors. If you start with a correct fluid level and new pads. The pad sensor would go first before the fluid level sensor if the pads are worn out. Assuming there's no leak in your system. Also, low fluid may not necessarily be due to worn pads.
edcarls is offline
post #13 of 14 (permalink) Old 08-08-2007, 07:47 AM
Premium Member
roncor's Avatar
Date registered: Jan 2005
Vehicle: '91 420 SEL, '80 240D, '87 560 SL, '93 190E Sportline, '70 300 SEL 6.3
Quoted: 36 Post(s)
Premium Member
thanks to everyone for that piece of info. i dont have an owners manual with me so i was confused what it was. once again thanks for helping me out
Get one here: - Every Repair Manual, Service Manual, Owners Manual and Book for your Car, Truck and Motorcycle
roncor is offline
post #14 of 14 (permalink) Old 08-15-2007, 12:07 AM Thread Starter
Date registered: Aug 2007
Vehicle: 1994 c220
it was the brake pads
rickyeby is offline
    Instrument Panel Blinking? smge1lc W163 M-Class 9 08-17-2010 10:56 AM
    Gear Indicator Instrument Cluster mmoghbelli W163 M-Class 2 03-25-2008 08:31 PM
    ABS/ASR Instrument yellow Lights are on swestbury R129 SL-Class 4 11-01-2007 12:23 PM
    anyone upgraded the 96-99 cluster to the 00-03 instrument cluster? will it work?? spine911 W210 E-Class 8 11-12-2004 04:24 PM
    Low Fuel indicator blinking, and Check Engine Light came on same time... LelloSLK R170 SLK-Class 7 09-30-2004 09:22 PM
