changing the fuses can save you lots of $$$ - Page 2 - Mercedes-Benz Forum
post #11 of 37 (permalink) Old 08-07-2007, 10:47 AM Thread Starter
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
Originally Posted by JOE55
I don't know everything but I am not taking your word for it.
First of all the Fuse break first before any major component get damage.
In electronics and electrical engineering a fuse, short for 'fusible link', is a type of overcurrent protection device. Its essential component is a metal wire or strip that melts when too much current flows. When the metal strip melts, it opens the circuit of which it is a part, and so protects the circuit from excessive current.
A practical fuse was one of the essential features of Edison's electrical power distribution system. An early fuse was said to have successfully protected an Edison installation from tampering by a rival gas-lighting concern.
Fuses (and other overcurrent devices) are an essential part of a power distribution system to prevent fire or damage. When too much current flows through a wire, it may overheat and be damaged, or even start a fire. Wiring regulations give the maximum rating of a fuse for protection of a particular circuit. Local authorities will incorporate national wiring regulations as part of law. Fuses are selected to allow passage of normal currents, but to quickly interrupt a short circuit or overload condition.
Fuse (electrical - Wikipedia, the free encyclopedia)
so I take it you never seen a fusebox catch on fire?
I have..
benz rider is offline
post #12 of 37 (permalink) Old 08-07-2007, 10:53 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 751 Post(s)
I refuse to accept that.
GeeS is offline
post #13 of 37 (permalink) Old 08-07-2007, 11:23 AM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
You have a point but normally fuse is the one that fails first...just my .02 cents
JOE55 is offline
post #14 of 37 (permalink) Old 08-07-2007, 11:29 AM Thread Starter
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
fair enough...
because one thing I know is... when a fuse gets too old and somehow "fuses" to the metal it's plugged into, that is a potential fire if one is not careful removing it. and MB fuses don't look burned or old which is odd...so I plan to change em out every 6 months to be on the safer side.
post #15 of 37 (permalink) Old 08-07-2007, 11:51 AM
amcnair's Avatar
Date registered: Mar 2006
Vehicle: 1997 E420
I've been around some car owners that are obsessive about maintenance, but I've never heard of anyone that would preemptively change his fuses every six months. That's a new one to me.
amcnair is offline
post #16 of 37 (permalink) Old 08-07-2007, 11:58 AM
amcnair's Avatar
Vehicle: 1997 E420
I have..
There are only a couple of ways a fusebox can catch fire.
1. The wrong fuses (or a rolled up piece of tinfoil) are installed.
2. The cover is left open to the elements, allowing in moisture, dust, etc.
3. A fire elsewhere has spread to the fusebox.
amcnair is offline
post #17 of 37 (permalink) Old 08-07-2007, 12:05 PM
amcnair's Avatar
Vehicle: 1997 E420
fair enough...
Now this is just silly. A fuse can "fuse" to its bracket if it corrodes, which normally doesn't happen on modern cars because the fuseboxes are sealed from the outside elements. Even so, how on earth could removing a corroded fuse start a fire?
I suppose if the car was running, and the fuse's circuit was under electrical load, the fuse could arc when you pulled it out. I guess if your pliers (or the fuse box) were soaked in gasoline, the spark could produce a fire.
But I think anyone who is changing fuses with gasoline-soaked pliers while the car is running is probably used to dealing with fires.
amcnair is offline
post #18 of 37 (permalink) Old 08-07-2007, 12:12 PM Thread Starter
~BANNED~
benz rider's Avatar
Vehicle: 97'C280
age and elements say sealed fuseboxes be damned.
post #19 of 37 (permalink) Old 08-07-2007, 12:39 PM
alexnatt's Avatar
Date registered: Feb 2004
Vehicle: 2000 e320 4matic
I think benz owners that change their fuses every six months are either on pedestals or are trailor queens.
2008 E350 4matic wagon
2000 E320 4matic wagon (sold)
2001 E430 4matic sedan (sold)
1989 300SE (sold)
1994 E420 (sold)
1988 300TE (sold)
alexnatt is offline
post #20 of 37 (permalink) Old 08-07-2007, 01:16 PM
JOE55's Avatar
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
fair enough...
I just talk to my SA @ MB of SF he said only replace the fuse if it's bad - you do not need to replace all the fuse if the fuse are okay otherwise it should be included in SERVICE B.
JOE55 is offline
Help Save me Money Part 2. Brabus CLK 500, what parts to cut? Where to Save Cash? Legion5 General Mercedes-Benz 1 06-18-2009 09:32 PM
Barrel Fuses vs. MB Strip Fuses 94Wagenmeister W201 190-Class 0 09-25-2006 06:09 PM
How much she save me ? Fatman Handsome W140 S-Class 8 08-10-2006 10:34 AM
Changing the fuses. 1993MB190E W201 190-Class 7 08-08-2006 07:08 PM
This is what I did to save $ NewMBie W126 S,SE,SEC,SEL,SD,SDL Class 0 06-26-2005 06:11 PM
