Instrument Cluster - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-05-2007, 03:25 PM Thread Starter
Date registered: Aug 2007
Instrument Cluster
Hello:
I own a '97 E320 and the analog guages in the instrument cluster do not
work...Speedometer, Tachometer, Fuel Level and Engine Temp.
Thankfully, the low fuel indicator light illuminates when the tank is running
low.
The digital functions all work fine...clock, odometer, etc.
The speedo and tach needles vibrate rapidly when the key is in the ON position and when the vehicle is running.
Can this be fixed?
If so, can I remove the instrument cluster without removing the steering wheel?
Any thoughts or advice would be greatly welcomed.
Thanks,
Kurt
kurtweidner is offline
post #2 of 4 (permalink) Old 08-05-2007, 03:37 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
The cluster can be removed by using pulling hooks, and usually lowering the steering wheel
ProgRama - Automotive Electronics, Remanufactured Automotive Parts, Ignition, Fuel Injection
www.MBCluster.com Homepage
and others
Peter Guenther is offline
post #3 of 4 (permalink) Old 08-05-2007, 09:19 PM Thread Starter
Where do you recommend I get the pulling hooks, or can I make them from coat hangers? Where do I insert them, about 10 and 2 oclock?
Thanks for the info so far!
Kurt
post #4 of 4 (permalink) Old 08-05-2007, 09:56 PM
devious12's Avatar
Date registered: Nov 2006
Vehicle: Mercedes 2002 CL600
Kurt
I have a Clk 98 I was able to pull out the cluster by placing my thumbs on the part of the dash right above the top of the cluster and using that as leverage while the tips of my other fingers were on the surface of the ceiling of the instrument cluster, grabbing tightly and pulling slowly. Then, doing the same thing on the bottom right, then left sides of the cluster. Slowly the entire unit came out, no damage. Hope it was clear enough, but not sure it will work on your car.
"Dude, your bed is a car...
Yeah, but it's a fucking sweet car"
devious12 is offline
    Instrument Cluster! Designo_E320 W210 E-Class 4 05-22-2007 12:51 PM
    instrument cluster markcaldwell W163 M-Class 2 01-11-2007 10:25 PM
    looking for instrument cluster. MB1990300E2.6 W124 E,CE,D,TD Class 3 03-24-2006 07:16 AM
    anyone upgraded the 96-99 cluster to the 00-03 instrument cluster? will it work?? spine911 W210 E-Class 8 11-12-2004 04:24 PM
    Instrument cluster mbfanatic W201 190-Class 0 02-04-2003 07:07 PM
