Check engine light on due to Tank Cap Loose - Page 3 - Mercedes-Benz Forum
post #21 of 22 (permalink) Old 07-27-2007, 05:50 AM
Mike Wevrick's Avatar
Date registered: Oct 2006
Vehicle: 2003 S500 4MATIC
I had this same problem and it turned out to have nothing to do with the gas cap. All the warning means is that there is a pressure loss somewhere in the fuel system. In my case it was charcoal cannister valve.
Mike Wevrick is offline
post #22 of 22 (permalink) Old 07-27-2007, 11:19 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
These other replies (and Mike's in particular) make clear that code diagnosis is often an ART, not a science, which explains the spreading of general misinformation that "the codes are wrong" (example of tomfoolery as requested).
For example, the code that started this thread can mean several things, such as the evap canister, the bank leak, etc., but in these cars it is *most often* a failing gas cap seal/vent. Thus, typically when that code is seen the first response is to replace the gas cap. On other makes that might not be the case, perhaps their canisters are undersized, etc., so they fail more often.
In any event, at this stage of the game it's not practical to put a sensor EVERYWHERE you'd like one and then have codes that are that specific (as are the 02 sensors, for example). So you have to have the experience person to tell you what a more general code is more likely to mean.
Take care and enjoy the ride,
Check Codes is offline
    Check Engine Light Due to Loose Gas Cap FixMyBenz W163 M-Class 6 04-17-2009 07:59 AM
    Check Engine due to Gas Tank Cap loose.. gahmed W220 S-Class 1 07-26-2007 11:25 AM
    Check engine light, result of loose gas cap JLuecht210 W211 E-Class 3 07-27-2004 09:54 PM
    check engine electronics light on due to K&N Air Filter? cabby850 W210 E-Class 2 11-06-2002 09:18 PM
    "Check Engine" light came on! First thing that came to mind was a loose gas cap, but it was not .... Beng R170 SLK-Class 6 02-13-2002 09:53 AM
