Anyone installed WIS on Vista? - Page 3 - Mercedes-Benz Forum
post #21 of 28 (permalink) Old 09-18-2009, 08:51 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Originally Posted by DarthDogCow View Post
If you look in the Windows Security Event Log and search for failure events at the same time you see the error, you'll probably find that you don't have the "Log On As A Service" right (although it may be a different right). If you can find the corresponding error in the Security log then post it here and I'll tell you how to add the right it wants.
If you don't see anything in the event log, you might need to turn on auditing. To do that, go to Start -> Run, and enter SECPOL.MSC. That'll fire up a GUI where you can set up the audit policy. Look under "Local Policies" -> "Audit Policy", and make sure "Audit Privilege Use" is set to log failures.
Hope this helps!
Warren
Thanks for the advice. Unfortunately this is not my computer and my friend is too far away that I could myself have a look at it. I've asked the user to send a few log files but did not receive them, I guess it was too difficult for him to figure out the folder I described and the files there.
I can always forward this info, hopefully he would either send the file to me or even better if he can follow the advice and fix the issue himself.
Thanks again.
Diesel Benz is offline
post #22 of 28 (permalink) Old 09-18-2009, 10:12 AM
DarthDogCow's Avatar
Date registered: Nov 2006
Vehicle: W211 E-Class (2003), R170 SLK (2000)
Thanks again.
OK, no worries. He can also use the SECPOL.MSC utility to assign the rights once he's found out which one he needs. "It's under Local Policies" -> "User Rights Assignment"
  • 2003 E 320 Avantgarde
  • 2000 SLK 200 Kompressor
  • 1926 Swift QA
"I never drink anything stronger than Absinthe before breakfast..."
DarthDogCow is offline
post #23 of 28 (permalink) Old 09-18-2009, 12:40 PM
Bimmerman4ever's Avatar
Date registered: Jun 2009
Vehicle: 99 Audi A8 Quattro 4.2 & 00 E320 4M
Quoted: 17 Post(s)
Originally Posted by nntp View Post
Is a version of WIS old?
It is from 01/2009 that it supported Vista.
Yes it's an older version
Tried to load it in XP SP3 but it will only load on SP2
it did load (partially) in Vista under XP SP2 compatibility mode
but it wasn't functional after PM
Past Euros: 91 MBZ 300TE, 91 Jaguar XJS V12 Coupe, 94 Alfa Romeo 164 LS, 80 BMW 320i, 85 BMW 528e, 86 BMW 325e, 88 BMW 325e, 88 BMW 325i Cab, 89 BMW 325ix, 91 325i Cabrio, 93 BMW 740i, 94 BMW 740iL, 95 BMW 525i, 78 Fiat Spyder 124, 98 Land Rover D1 LSE, 93 MBZ 190E 2.6, 96 MBZ C280 Sport, 93 MBZ 400E, 90 MBZ 300ce, 92 MBZ 500SL, 71 MGB-GT, 91 VW Corrado G60
Bimmerman4ever is offline
post #24 of 28 (permalink) Old 09-21-2009, 08:57 AM
Date registered: Sep 2009
Smile
I got a WIS 2006 copy with the car I bought., I finally got it to work on a IBM computer with the new Windows 7 OS. But after I ran it throgh some it popped up message that the CD was more than 3 months expired, and shut down. Well I changed date to Dec. 2006 and then it worked again. I did not know the disc had a time limit. These WIS disks seem not only very hard and frustrating to install., but not all that usefull when you get them going. Maybe someone that has a lot of experience with them can make heads or tails from them. There is a disc set on ebay, kinda expensive, but in demo seem much easier and more informative than WIS. Has anyone tried those?
sagebrush is offline
post #25 of 28 (permalink) Old 09-21-2009, 12:11 PM
Quoted: 35 Post(s)
You could be a bit more specific, an expensive disc set on ebay could be almost anything. Would you have a link to an example ebay item?
If it is SD Media, that is intended to support DAS (Xentry), if it is Star Finder, that is mostly the same documents as WIS plus illustrations of actual parts' locations in the car.
post #26 of 28 (permalink) Old 09-21-2009, 12:41 PM
I am sorry, the manuals I am thinking of are not on ebay, They are Mercedesmanuals.com,Star Classic Service manual library. For model 129 they are 157.00 Been looking at so much stuff lately.
post #27 of 28 (permalink) Old 09-30-2009, 10:24 PM
Date registered: Jul 2009
Vehicle: '13 E350 BTC, '06 E320 CDI
Quoted: 6 Post(s)
I am running Windows 7, .... I went through I don't know how many steps and never got to the point where it would work, finally gave up.
I just downloaded and installed the free Microsoft Virtual PC and XP Mode from Microsoft and WIS appears to work just fine. The only problem so far is that the virtual PC defaults to the highest monitor resolution supported. Setting the screen resolution to a lower value only reduces the window size rather than making the contents appear larger. Any way, the MS Virtual PC works in Win 7 and the price is free.
Give it a try and see if it works for you.
Mike
Werkstattmeister is offline
post #28 of 28 (permalink) Old 06-12-2010, 01:57 AM
Date registered: Jun 2010
Vehicle: 1999 CLK 320
Yes, I did. An older version of wis, that was not supposed to work with vista. All i did was follow the install directions exactly, but before installing anything I went through and selected xp compatibility on all the exe and bat files. From there, I ran the first installation process as an administrator and haven't had any issues.
vxvxs is offline
    WIS/ASRA plus EPC installed and running Teutone W126 S,SE,SEC,SEL,SD,SDL Class 8 07-18-2009 12:32 AM
    Wis and Windows Vista lloyds W220 S-Class 6 09-18-2008 05:17 PM
    First impression of Vista ThrillKill Off-Topic 33 07-12-2008 11:03 PM
    Anybody using Microsoft Vista yet? KamiL Off-Topic 86 06-28-2007 10:51 PM
    Installed the big WIS/ASRA System.. allerton W126 S,SE,SEC,SEL,SD,SDL Class 2 12-01-2006 09:46 PM
