Help!! Overheating! - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-21-2007, 12:10 PM Thread Starter
Date registered: Jul 2007
Vehicle: 1998 ml320
Thumbs down Help!! Overheating!
I have a 98 320 ML that I just purchased and the temp is between 80-100, as I start driving, it starts going up, so far...never past 100, but I am concerned, is this supposed to happen? It just goes up and down slowly between 80-100, and I'm scared that it will eventually overheat! Please help. Also, the antifreeze level is not at the indicated mark. Should I put more antifreeze in it?
therosey2k is offline
post #2 of 7 (permalink) Old 07-21-2007, 12:12 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
post here:http://www.benzworld.org/forums/w163-m-class/
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
post #3 of 7 (permalink) Old 07-21-2007, 04:27 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, rosey, welcome to the forum.
There are lots of things that might explain this.
If you don't know when the last time was that the cooling system was flushed and inspected, start there. It could be a cooling fan, partially blocked radiator, leak, sticking thermostat, etc. But I'd suggest starting with a flush and inspection, then go from there.
As your other reply noted, the general forum is typically not the best place to find help about a specific model, that's what the specific forums are for, so scroll on down until you see the 163 forum and pick their brains.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #4 of 7 (permalink) Old 07-21-2007, 08:38 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
Temp fluctuation is normal in MB.
I woudn't worry unless it start actually reaching 100. Boiling point for pressurized coolant is above 115 C.
Kajtek1 is offline
post #5 of 7 (permalink) Old 07-21-2007, 08:39 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 90 Post(s)
You can try searching the w163 forum as well. The search button is in the upper right hand side of your screen.
Mike
Michael Pillay is offline
post #6 of 7 (permalink) Old 07-21-2007, 08:42 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
Yup, seems all Mercedes run hot, it's a characteristic of the brand.
GeeS is offline
post #7 of 7 (permalink) Old 07-21-2007, 08:48 PM
79Mercy's Avatar
Vehicle: 1979 280CE
Quoted: 2 Post(s)
does anyone know why. On my other american made car it has a digital display that show all about the motor oil pressure, temp,odo. I pressed the button to make the temp show one day while sitting in traffic and it got up to 220F and the normal gauge didn't even move when it got that hot.
79Mercy is offline
    overheating dannyboi R170 SLK-Class 2 06-22-2007 03:17 PM
    Overheating jbadgio W201 190-Class 3 07-24-2005 01:17 PM
    Overheating?? hornbrod W201 190-Class 7 07-19-2005 04:00 PM
    Overheating Pistolero63 R129 SL-Class 2 03-18-2005 06:10 PM
    Overheating Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 3 10-04-2001 01:48 AM
