Has you car ever been stuck in a flood? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-20-2007, 01:15 PM Thread Starter
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 343 Post(s)
This is not my problem - yet.
There have been rainstorms in southern England today. and quite a lot of guys will have returned from work today to discover their home & possibly their car is sitting in about 2 - 3 feet of water from a nearby overflowing river.
So how much water is too much? Has anyone here rescued a car where the engine was fully under water? Just wondering...
keyhole is online now
post #2 of 2 (permalink) Old 07-20-2007, 03:29 PM
Kajtek1's Avatar
Quoted: 1070 Post(s)
I killed one car in flood, while driving if that counts.
Modern engines are pretty well sealed. The only critical point (as I experienced) is air intake. In my case it was less than 2' above the ground, right behind front grille. Once I pushed water over the hood, the engine was breathing the water as well.
On parked car if you don't have water marks entering the car interior, don;t think you have anything to worry about. If you do -I would check for water in the air filter and water in oil. If they don't have any signs of water -the engine is ready to turn. To be on safe side you can turn it by hand using socket on the main pulley, or on manual transmission by pushing the car on second, or third gear.
Even if engine flooded, you can pull the plugs, crank it to blow the water off, change the oil and it should be ready to go. I used to have my jet-ski engine flooded several times. On 2-cycle it usually took turning the engine upside-down to get water off the crankcase.
Kajtek1 is online now
    Can you say "FLOOD" cmitch Off-Topic 7 03-19-2006 07:49 AM
    Car Flood JonnyBlayz W220 S-Class 7 01-29-2006 02:38 AM
    Car stuck at Wendy's Please help! Docjay R170 SLK-Class 30 09-28-2005 10:26 AM
    flood esde Unimog 0 07-27-2005 01:31 PM
    I didn't see the flood........ tjalexander R129 SL-Class 4 05-30-2005 03:17 PM
