Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 07-18-2007, 06:22 PM   #1 (permalink)
Date registered: Jul 2007
Vehicle: 2001 M 320 SUV
automatic window not working
My automatic window is no longer working. The motor is still functioning and turning the gear, but it no longer repositions the window at all. The window is properly positioned in the clamp. How do the gear and the lever arms join?
savvygirl is offline   Reply With Quote
Old 07-18-2007, 06:26 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hi, savvygirl, welcome to the forum.
You're likely to get much better help if you repost in your SUV's native forum, scroll down the main forum page until you see the W163.
That said, I'm not familiar enough with the ML to know whether it's plagued by the window regulator problem, but the W210 class is, so perhaps it's the regulator. I'm sure some of the other ML owners can set you straight, though.
Take care and enjoy the ride,
Greg
Meister Eckhart
Automatic window fouling savvygirl W163 M-Class 0 07-18-2007 06:09 PM
Automatic closing doors not working Bee W140 S-Class 5 03-23-2006 06:33 AM
Automatic Volume Control Working? gmabli R171 SLK Class 25 12-05-2005 09:44 AM
Automatic door locking not working rogereriksen W163 M-Class 7 06-07-2004 10:58 AM
ACC (automatic climate control) unit not working. Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 09-12-2000 03:16 AM
