2000CLK 430 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-17-2007, 07:15 AM Thread Starter
Date registered: Jul 2007
2000CLK 430
I've seen a couple of other postings regarding a vibration at idle while in drive. I have the same problem on a Clk with 130K. I don't believe it is transmission or torque converter. Does anyone have alternatives?
fuddsmb is offline
post #2 of 4 (permalink) Old 07-17-2007, 07:31 AM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
Greetings and welcome to Benzworld FUDDSMB!
You may get more response in the W208/CLK section, but I'll try to answer the question - in most cases, it's the motor mounts. Those are regular wear items. They age, crack, the fluid leaks out, and then the vibrations are transmitted to the chassis. The transmission mount will wear out eventually too.
If you're a DIY type, you can knock out the motor mounts on a Saturday morning. If you're a TII type (take it in), your mechanic can knock it out in a morning.
MarcusF is offline
post #3 of 4 (permalink) Old 07-17-2007, 07:59 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, Fuddsmb.
I'll second Marcus' welcome, as well as his preliminary diagnosis. That's a fairly common issue and solution.
To parrot Marcus further, there is a forum specific to your car, it's the W208 forum, just scroll down the list and you'll see it. Lots of good folks and good information in there.
I guess the one thing I could add to Marcus' post: if you are a TII guy, your mechanic will knock it out in the morning and then knock you out with the bill.
Take care and enjoy the ride,
Check Codes is offline
post #4 of 4 (permalink) Old 07-18-2007, 09:17 AM Thread Starter
Thanks for the info. I will redirect to the 208 section.
fuddsmb is offline
    CLK 430 & CLK 430 AMG bjorkson C208/A208 CLK-Class 179 12-16-2012 09:14 PM
    Radio CODE need help 2000clk crsh2 C208/A208 CLK-Class 2 06-24-2007 07:16 AM
    How Much Can I get for my 430? juntao C208/A208 CLK-Class 1 10-14-2005 12:37 AM
    Rocker Panel shattered 2000CLK jratlanta C208/A208 CLK-Class 0 06-21-2002 06:49 PM
    ML 430 Emre W163 M-Class 1 03-22-2002 02:58 PM
