does flushing brake fluid help the brake pedal feel firmer & stop faster? - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 07-09-2007, 09:37 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
Originally Posted by johnhef
I never noticed a difference in all the new cars I work on, but I just changed the fluid in a 240D that had been sitting for at least two years and who knows how long it had last been changed before that. The brake fluid was black and it had a extremely soft pedal and I was suspecting frozen calipers but after a brake flush, what a world of difference. It may still have a stuck piston or two but it feels at least 70% better, the pedal is firm again.
But how could you know the improvement was not from bleeding? As long as it's got some liquid and no air, it should not feel soft.
Perhaps if it has produced foam, like water in engine oil, then it would be impossible to get the air away with bleeding (if not putting new fluid in, which would be normal with bleeding).
In any case, fluid change should have been done a lot earlier already because of the risk of corrosion.
Diesel Benz is offline
post #12 of 14 (permalink) Old 07-09-2007, 03:37 PM
johnhef's Avatar
Date registered: Mar 2007
Vehicle: Too Many
Send a message via AIM to johnhef
true. it may have had air in it. either way don't let it get that bad
Master Certified 10 years MB tech
1980 500SE Euro
1981 500SEL Euro
1982 380SEL
1983 500SEC Euro
1983 300TD
1984 500SEC - parts car
1984 300TD Euro
1985 190E 2.3-16 Euro
1986 190E 2.3-16
1986 190E 2.3-16 Lemons
1987 300D
1999 C230K
2003 C320T-4
2003 E55
johnhef is offline
post #13 of 14 (permalink) Old 07-09-2007, 04:59 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
Originally Posted by ProV1x
as old brake fluid degrades slowly over time, do the brakes start to perform worse? is there a noticeable drop in pedal firmness and how soon the brakes grab?
Yes, yes, and yes - however, brake feel is a relative term. That and it depends on how the car is driven. In a normal stop-and-go environment, it's tough to tell whether a system is filled with fresh fluid or 5 year old sludge. A few laps on track day will expose old fluid. Brakes get hot. They get hot enough to boil the fluid in the calipers. When brake fluid boils, it changes from a liquid to a gas. Gas is compressible. That compressible gas is what causes the long pedal travel and the spongy "feel". If this is ignored for a few laps, the brakes can fail completely. When this happens, the driver is typically elected to the "entertainment committee".
I rotate between ATE Blue, and Gold every other year. It's a DOT4 fluid and according to the container in my garage, it's rated at 536˚F/392˚F. Those two numbers are the dry and wet boiling points. Brake fluid is hygroscopic, which means it absorbs moisture. As it absorbs moisture, the boiling point lowers, which reduces it's performance. After a few years, that firm pedal that initially required 536˚ before the fluid boils, now starts boiling at 70% of what it took when the fluid was new. On track days, this lower boiling point forces one to start braking a lot earlier. The reason I rotate between those two colors is because when I flush the system, I can see that I'm done at one corner because the color changes.
MarcusF is offline
post #14 of 14 (permalink) Old 07-09-2007, 10:58 PM
Quoted: 32 Post(s)
The technical facts from MarcusF make it easier to understand the issue. Thanks.
    Flushing out old brake fluid inside ABS pump without software me_benzing The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 12-07-2012 04:53 PM
    Flushing with new brake fluid ? Jason Lap W126 S,SE,SEC,SEL,SD,SDL Class 4 12-19-2005 08:11 AM
    Flushing ML Brake Fluid N1ML W163 M-Class 3 02-15-2005 11:54 AM
    DIY link for flushing brake fluid? JAD W163 M-Class 1 06-01-2004 01:21 PM
    ***Question*** ML brake pedal feel Al W163 M-Class 2 06-17-2001 06:23 AM
