Climate Control - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-06-2007, 04:11 PM Thread Starter
jr330's Avatar
Date registered: Apr 2007
Climate Control
The fan speed dial on my '06 C280 does not seem to increase as you dial from 0-max. In both auto or a/c mode or in combination. Does the temp setting relate in any way to the fan speed? The air seems to be blowing out at a constant rate.
Thanks anyone.
jr330 is offline
post #2 of 3 (permalink) Old 07-11-2007, 07:52 PM
Date registered: Mar 2007
u have a 06 bring it to the dealer lol. but sounds like ure acc control
nalee is offline
post #3 of 3 (permalink) Old 07-11-2007, 09:59 PM
Diesel Benz's Avatar
Quoted: 40 Post(s)
I guess he first wanted to know if there is a fault in the first place. I'm not sure about a C-class but generally in auto-mode the fan speed is dependent on the temp setting and the internal and the external temperature, and if A/C is on or off. The point being that the auto setting tries to estimate how much air flow is needed and tries to keep it comfortable.
But you would always have a manual fan speed setting option, then it should follow your setting, irrespectively if A/C is set on or off.
Diesel Benz is offline
Climate control NZSL R129 SL-Class 13 10-02-2008 03:40 PM
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 09:51 PM
climate control kickboxer W126 S,SE,SEC,SEL,SD,SDL Class 0 10-17-2005 04:15 PM
climate control maltadoc W140 S-Class 4 09-06-2005 07:26 PM
climate control COOPER W124 E,CE,D,TD Class 3 01-16-2003 07:30 AM
