1999 ML320 misfires - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 09-11-2007, 06:27 PM Thread Starter
Date registered: Jul 2007
Replaced all plug wires which resulted in the engine running better. The misfire still occurred but on a more regular basis. (Daily at the start of a trip the misfire would occur, the engine ran rough and the Check Engine light would come on. The Misfire went away when the car was turned OFF then back ON. Eventually the Check Engine light would go off by itself. The next day the cycle repeated.) Here's what the mechanic did and I have gone almost a month and 500 miles with no misfires. He "retrained" the computer to tell it where the crankshaft was.
Thanks for all the tips and I hope this may help someone in the future.
bobernst is offline
post #12 of 15 (permalink) Old 09-11-2007, 11:38 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Just curious, did he retrain it by replacing the crank position sensor? That's a fairly common problem area on the 320 V6 and could account for your symptoms.
Check Codes is offline
post #13 of 15 (permalink) Old 09-12-2007, 01:41 AM
dumokie's Avatar
Date registered: Sep 2006
Vehicle: 1998 slk 230 (r170), 1998 ml 320 (w163), #8,#24,#17 Nascars for promotional events see homepage.
Send a message via Yahoo to dumokie
Not much help But here we go.
I remember seeing a post here refering to the wiring to the coils failing/shorting something?? I can't remember....... I remember it was a 320.. Have you done a search for ML320 coils, wiring, etc. I know thats not much help but vaugely remember it and they included fix in post.
Dumokie
dumokie is offline
post #14 of 15 (permalink) Old 09-13-2007, 05:48 PM
ctbenztech's Avatar
Date registered: Aug 2007
Vehicle: ml430
he did not retrian where the crank shaft sensor is.there is no such thing. i bet he reset adaptaions for the mass air flow sensor. what you discribe is exactly what happens when some one replaces a maf and does not rest computer. was this a mb dealer that changed the maf? was it the same person that "reset" the crank shaft sensor. the ME(brain of car) either gets a signal or doesnt from the sensor. if the sensor goes haywire then it needs to get replaced not "reset".
ctbenztech is offline
post #15 of 15 (permalink) Old 09-13-2007, 07:50 PM
joesnextoy's Avatar
Date registered: Feb 2004
Vehicle: drive them all
Send a message via AIM to joesnextoy
ct benz
yes you can reset adaptation of the crank sensor
it is called ring gear adaptation and you do it when you replace the crank sensor or motor mounts
joesnextoy is offline
1999 ML320 vs. 1999 RX300, which is better ? mbeclass W163 M-Class 8 05-15-2015 03:20 AM
My 1999 ML320 pize98 W163 M-Class 33 03-09-2006 02:24 PM
***FOR SALE*** 1999 ML320 Stewart For Sale/Wanted/Trade/Giveaway 2 11-27-2005 02:02 PM
1999 ML320 Value pize98 W163 M-Class 4 11-18-2005 12:07 PM
New (to me) 1999 ML320 Dr Stewart Ginsberg W163 M-Class 1 01-26-2002 07:22 PM
