ASR Diagnostics - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 06-26-2007, 02:05 PM Thread Starter
Date registered: Jun 2007
Vehicle: 1995 SL 500 2005 SL500
Quoted: 5 Post(s)
Post ASR Diagnostics
I found this info today on a Mercedes technical bulletin and though I'd share it.
This could help expedite an ASR diagnosis: If the ASR light comes on while driving and stays on until the ignition is turned off, but the accelerator pedal feels and functions normally, you've most probably found a failed pressure pump
(either return/pressure or the charging pump), a bad pressure reservoir or a leak in the hydraulic circuits. If the ASR light comes on under the same circumstances,
but the accelerator pedal is harder to push and the engine power output
is noticeably reduced, the problem is more likely in the electronic accelerator system rather than in ASR.
Lee Wireless is offline
    OK! New problem! Just fixed the asr light, today, both the asr and the abs lights has come on! Cabbe W140 S-Class 23 04-12-2015 10:13 PM
    WinSTAR Diagnostics..... kenzed R171 SLK-Class 2 06-21-2007 10:18 PM
    Diagnostics Software rudboi510 W140 S-Class 0 04-04-2007 05:29 PM
    Diagnostics BIFFO-911 General Mercedes-Benz 1 07-11-2006 08:00 AM
    126 diagnostics Aussie560sel W126 S,SE,SEC,SEL,SD,SDL Class 3 07-18-2005 04:56 AM
