2005 SL500 oil leak - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-20-2007, 09:35 PM Thread Starter
Date registered: Dec 2006
2005 SL500 oil leak
I have a slight oil leak coming from the extension on the left valve cover (where the oil filler cap attatches). I noticed it is a rubber sealant and not a gasket. Anyone ever repaired one of these?? I have never removed the LARGE plastic top cover to the engine. Any thoughts?? Thanks in advance!! FG
funnyguy1 is offline
post #2 of 4 (permalink) Old 06-21-2007, 02:34 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
i repair these all the time at work. yes its the chambers that are leaking. just remove the valve cover, remove the 3 torx bolts holding it on and carefully pry it off, clean all the old sealant and install new sealant and reinstall. replace the valve cover gasket too
Streetglower is offline
post #3 of 4 (permalink) Old 06-21-2007, 08:30 AM Thread Starter
Thanks Streetglower! How do you remove the whole plastic top assembly to get to the valve covers/oil filler neck?? It is very intimidating. Thx
post #4 of 4 (permalink) Old 06-21-2007, 10:01 AM
azinn's Avatar
Date registered: Apr 2003
Vehicle: 2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
This should be covered under the Factory Warranty, 4 years, 50,000 miles. My 2 cents.
azinn is offline
    Oil leak from windshield frame 1998 SL500 Wild Charles R129 SL-Class 12 05-18-2013 05:17 PM
    2005 SL500 fluid leak?? funnyguy1 General Mercedes-Benz 1 03-13-2007 03:10 PM
    Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 11:24 AM
    oil leak... motor honey?...leak stop? b2d W123 E,CE,D,CD,TD,TE Class 1 04-11-2005 04:07 PM
    My car is in the shop...Oil leak, windshield washer leak, and screw came off. chanm W163 M-Class 3 05-23-2003 07:21 AM
