Any Ideas? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-18-2007, 01:48 PM Thread Starter
Date registered: Jun 2007
Vehicle: 2002 C230K; 1998 Saab 800S; 1995 Mazda Miata; circa 1980 John Deere 170
Any Ideas?
My C230K has me stumped so I am dropping it off at the shop tonight. Two symptoms:
1) When accelerating from say 65-75 the car seems to be "skipping" a little and gives a slight jolt, if you know what I mean. If just cruising along at around 70 it runs fine - only when accelerating.
2) When coming to a hard (but not too hard) stop, the shift from 2nd to 1st is rough. If you come to a gradual stop, there are no noticeable problems.
Routine maintenance is within my capabilities but this isn't something I want to screw around with.
Anyone have any ideas as to what this may be? $$?
macneilc is offline
post #2 of 5 (permalink) Old 06-18-2007, 02:00 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, macneil, welcome to the forum.
Generally speaking when you're asking questions pertaining to your model, you're better off posting in your car's native forum (W203).
You also didn't mention mileage. If you're in the 60K plus range it could be a fuel filter, but best to let the shop pull codes and see if that shows anything. Codes get stored even though the CEL may not come on.
Also, if you're at or above 50K miles, it's time for an AT fluid and filter change, which probably will resolve the shifting issue. That gets ignored all the time and it definitely causes some odd symptoms as well as shortening the life of the transmission.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 5 (permalink) Old 06-19-2007, 08:56 AM Thread Starter
Thanks Greg for the great advise and insight into what may be going on.
She's got 83K miles on her so hopefully it's simply a maintenence think. I am the second owner and unsure how the previous owner treated the car.
I'll follow up once she's fixed.
macneilc is offline
post #4 of 5 (permalink) Old 06-19-2007, 09:06 AM
Vehicle: Volvo 940GLE, GMC Suburban, Infiniti I30, Toyota Prius, VW GTI, MB SLK350, Lexus IS250
Seems transmission related. In the 65-75 acceleration, was it in same gear or with a down shift? Have you checked the tranny fluid level yet?
CalifSLK is offline
post #5 of 5 (permalink) Old 06-21-2007, 11:33 AM Thread Starter
I am praying AT fluid change will fix the issue but it's still at the shop being diagnosed. While accelerating in the 65-75 + range the skipping occurs in the same gear - without any downshift. I haven't checked the fluid only because I don't have a dipstick.
macneilc is offline
    Any Ideas? pedro.b W201 190-Class 17 07-11-2006 10:45 PM
    any ideas for breathing new life into 116? ideas? MrNemo Vintage Mercedes-Benz 15 11-19-2005 08:47 AM
    Name Ideas Cyycopath Off-Topic 15 01-11-2005 09:05 PM
    Any Ideas? DUTCH G-Class 4 10-19-2003 07:59 PM
    I've run out of ideas, does anyone have any new ideas on any SLK modifications? ImportTunerTyp R170 SLK-Class 15 01-10-2003 11:20 AM
