Very dark oil immediately after change ('74 240D) - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 06-17-2007, 06:26 PM   #1 (permalink)
Date registered: Sep 2006
Exclamation Very dark oil immediately after change ('74 240D)
Still messing with my dad's '74 240D project, destined to run on biodiesel from waste vegetable oil. Currently still on pump dino-diesel.
The oil was very black when we got the car, so I changed it and my dad has driven it some since then. I checked it again last week, and it was black again. Just working some of the old crud out from the previous owner, right?
I changed the oil again, backed the car off the ramps and had lunch. When I checked the oil level, it was very dark already! I suspect the engine has quite a bit of blowby, but it shouldn't be this dark after just letting the engine run for 2 minutes, should it?
Any guesses as to what's causing this? Is it picking up sludge from the oil pan or front mounted oil cooler? I know engine flushes can pretty much kill an engine, but is there some safe type of flush or cleaning agent I can run? Thanks.
Jason
FieroGT42 is offline   Reply With Quote
Old 06-17-2007, 06:42 PM   #2 (permalink)
bgoin's Avatar
Vehicle: Classic 92 190E 2.6
Jason
You can drop the oil pan and see or next time you drain the oil get a small wire and make a loop and put it in the drain hole (trying to bend it down on the oil pan bottom) and then pull out and see if you get a lot of sludge/crud on it.
bgoin is offline   Reply With Quote
Old 06-17-2007, 06:52 PM   #3 (permalink)
Premium Member
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Premium Member
Engine flushes are pretty much a damned if you do or don't scenario. Lots of cases like yours that the engine really needs it but, what do you do?
I got the same thing with my 99 ML430. Change the oil and one trip in it and the oil was tar black. I thought after 2 years of 3000 mile oil changes, I'd worked it all out but it didn't. My vehicle consumed 1 1/2 to 2 quarts of oil per month and rattled every morning on cold crank-up for about 5 to 10 minutes! I had enough. I got some GUNK motor flush and warmed the engine for about 4 minutes and then shut it off, poured the stuff in and then cranked her back up. I let it run about 10 minutes afterward. I drained the crud out (and it was alot!) and refilled with Mobil 1 10W40. It hasn't used a drop of oil since, no rattles and the oil stays clean.
Now, don't think this will be everyone's result because I've seen engine flushes go bad as well. A Pontiac Parisienne filled the valve covers full on a friends car. There was so much crud it stopped up the drain back ports. It was a god awful mess, too. He had me help him remove the valve covers and oil gushed out down the side of the engine. It took a coat hanger and nearly a case of WD40 to clear out the drains on one of the heads. I found out that he poured the motor flush in a COLD ENGINE and then cranked it up. I don't know for sure if the results would have been different had he warmed it up first, but I think it would.
If you do decide to flush, be aware it could do this. Be prepared to take off valve cover and deal with a huge mess if it doesn't work out. If it were mine, I'd do the flush but only on a warm engine but that's me. There are just as many here who would be adamant about NOT flushing it.
Bells and Whistles are Thorns and Thistles.
2005 S430 4Matic W220.183 • 722.671 Transmission
cmitch is offline   Reply With Quote
Old 06-17-2007, 07:20 PM   #4 (permalink)
Vehicle: Volvo 940GLE, GMC Suburban, Infiniti I30, Toyota Prius, VW GTI, MB SLK350, Lexus IS250
Jason
Black oil is normal for a diesel. This was when I stop changing oil after getting it all over myself the first time.
CalifSLK is offline   Reply With Quote
Old 06-18-2007, 06:01 AM   #5 (permalink)
POS
POS's Avatar
Date registered: Oct 2005
Vehicle: 1985 190E 2.3-16 AMG, 1986 300E LeMons, 1971 300SEL 6.3
Very normal.
- Brian
1969 Porsche 911S Targa
1966 Mercedes 250SE Cabriolet (adopted)
1971 Suburban 4x4
POS is offline   Reply With Quote
Old 06-18-2007, 06:57 AM   #6 (permalink)
Nimrodthewombat's Avatar
Date registered: Dec 2002
Vehicle: 1993 500 SEL (W140) 1992 500 SL (R129) 1995 E300 Diesel Special Edition (new kid on the block)
Ditto. When I got my first diesel I got hysterical because the oil was always black! A good friend of mine who was an MB tech for 35 years said it's because you can never really FULLY drain all of the oil out. About a half a quart remains in the oil cooler and lines and when you start the car up after the change it mixes with the new causing the black
Don't worry about it.
1993 500SEL (W140) the King of the road!
1992 500SL (R129) mid life crisis present
1995 E300 Diesel Special Edition (W124) The "practical" car
"I'd rather be crying in the back seat of a Rolls-Royce than laughing on the back of a Vespa!" Madame Gucci
Nimrodthewombat is offline   Reply With Quote
Old 06-18-2007, 07:39 AM   #7 (permalink)
Yacht Master's Avatar
Date registered: Nov 2006
Vehicle: E-ZGO 53 HP., 99 E 430 sport, 04 E55 AMG, 2008 Tahoe LTZ Sold Porsche to Brother
Jason
That is just the way it is, no problem, normal. Not a good idea to flush a diesel.
Yacht Master is offline   Reply With Quote
Old 06-18-2007, 10:09 AM   #8 (permalink)
Ok then, thanks. I won't let my dad get the engine flushed, but I think I'll drop the oil pan next change and clean any sludge, maybe blast something through the oil cooler to make sure the passages are clear.
Old 06-18-2007, 10:47 AM   #9 (permalink)
Date registered: Jun 2006
Vehicle: 1983 W123 300CD OM617: 1992 W124 400E M119
Send a message via AIM to mrhills0146
Overkill. Not necessary - the only reason you'd have a sludging problem is if previous owner either never changed the oil or rarely changed it w/ non-Diesel rated oil.
If you insist on going overboard, you can run a full synthetic oil which has some solvent/detergent-like properties. But even that is really unnecessary on an old robust car like you're dealing with.
Matt in Atlanta
1983 300CD
Black-on-black daily driver
299K and laid up right now
Former:
1992 400E, smoke silver-on-mushroom, sold at 168K
mrhills0146 is offline   Reply With Quote
Old 06-18-2007, 11:10 AM   #10 (permalink)
mdvijay's Avatar
Vehicle: SL55,G500,C320,F430SPIDER
agree as above...diesel oil will turn black
vijay
mdvijay is offline   Reply With Quote
Bookmarks
Oil Change in 81 240d cause lack of power and lower oil PSI? Cobb2 W123 E,CE,D,CD,TD,TE Class 12 07-15-2008 10:51 PM
need help/advice on oil level/dark smoke on exhausts xdgr8 W124 E,CE,D,TD Class 3 06-19-2007 12:51 AM
saw a great looking pewter SLK 350 with dark dark tint on the 60 fwy connecting to 60 cyberdrakon R171 SLK Class 0 05-25-2007 12:42 PM
'83 240D issues and oil change Synchr0 W123 E,CE,D,CD,TD,TE Class 11 05-30-2006 01:01 PM
Oil turns dark fast! izeljic W123 E,CE,D,CD,TD,TE Class 4 03-11-2003 12:45 PM
