Very dark oil immediately after change ('74 240D) - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 06-18-2007, 01:02 PM
Posts: n/a
Quoted: Post(s)
Diesel oil will turn black in a second after you start it. FLUSHES? I will tell you my experience with a 1977 240D. I did a flush every 6 months. So first I drained the oil, took off the oil pan, cleaned it, then I would put in the flush and also approximately 2 quarts of pure diesel and filled the rest up with oil, started it and let it idle for no more than 3-4 minutes. Shut it off, drained the oil and again took off the pan and cleaned it again and put everything back. Lot's of shit use to come out. Filled with oil, started it and let it idle for 10 minutes before driving it. YOU MUST BE VERY CAREFUL AS YOU CAN ALSO GET METAL TO METAL FRICTION IF YOU ALLOW THIS TO RUN FOR TOO LONG AND ACTUALLY CAUSE DAMAGE.
WHAT HAPPENED TO THE CAR? Well, when I sold it, the car had a little over 500,000 miles ON THE originaL engine which was NEVER OPENED for anything and performed better than most with only 100K miles. The only maint. that was done by the pros was the valve adjustments. It was a stick and not an automatic so it was faster or at least seemed faster anyways. It was white in the beginning and then I changed its color to maroon. BTW, I had bought it with only 90K miles on it I think but I'm sure it was no more than a 100K
post #12 of 13 (permalink) Old 06-18-2007, 05:45 PM
Date registered: Oct 2005
Vehicle: 79 300SD
Use diesel rated oil, check the oil levels on a warm engine often, top off if needed, and change the oil and filter every 3000-5000 miles. It really is this simple.
Chaw is offline
post #13 of 13 (permalink) Old 06-19-2007, 05:33 AM
Date registered: Mar 2003
If you use a reputable diesel rated synthetic, and have a really clean engine, it is possible to have the oil looking honey colored after an oil change. 100 miles later, it may be a bit darker. By 1,000 it should be nearly black.
Its a strange phenomenon to have a diesel with honey colored oil.
DslBnz is offline
    Oil Change in 81 240d cause lack of power and lower oil PSI? Cobb2 W123 E,CE,D,CD,TD,TE Class 12 07-15-2008 10:51 PM
    need help/advice on oil level/dark smoke on exhausts xdgr8 W124 E,CE,D,TD Class 3 06-19-2007 12:51 AM
    saw a great looking pewter SLK 350 with dark dark tint on the 60 fwy connecting to 60 cyberdrakon R171 SLK-Class 0 05-25-2007 12:42 PM
    '83 240D issues and oil change Synchr0 W123 E,CE,D,CD,TD,TE Class 11 05-30-2006 01:01 PM
    Oil turns dark fast! izeljic W123 E,CE,D,CD,TD,TE Class 4 03-11-2003 12:45 PM
