Evaporator Temperature sensor - Page 3 - Mercedes-Benz Forum
post #21 of 44 (permalink) Old 06-17-2007, 07:39 AM Thread Starter
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 5 Post(s)
I believe it is for a W210(see large numbers) The W208 shares many parts with the Eclass. My cabin filter also was for a W210.
ThrillKill is offline
post #22 of 44 (permalink) Old 06-17-2007, 08:16 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
lets start from the beginning because you have me confused and yourself confused.
what exactly is the problem with the car?
second pull the sensor out of the bag so I can see the sensor
Streetglower is offline
post #23 of 44 (permalink) Old 06-17-2007, 10:03 AM Thread Starter
ThrillKill's Avatar
Quoted: 5 Post(s)
OK.
The compressor is working as I can hear it engage and the EC light is off. It is however blowing air relative to the temperature of the engine.
Through diagnostics I was able to determine that freon was slightly low and that it was registering evaporator temperatures of anywhere between 125 and 140F, an impossibility. I also pulled up codes 241 (Refrigerant Low) and 227 (Outside Temperature Sensor Malfunction).
I added as much freon as possible (in 6 minutes only 1/2 can could be dispensed) This made the low refrigerant code disappear however it still registers as only 25 psi on the guage.
sorry for the horrible phone pictures.
post #24 of 44 (permalink) Old 06-17-2007, 10:42 AM
Quoted: 4 Post(s)
well i am not one to diagnosis codes through the control panel i prefer star diagnosis
anyway now that we have determined that you indeed have a new evap sensor, you need to install it. again start by removing the driver underdash panel. once that is done, look at the accelerator pedal and then look up to the right. you should see the evap sensor sticking into the heater housing. again the heater housing is what houses the evaporator and heater core. it sits behind the dash. if your confused about this, take a pic under the dash and I will guide you too it.
post #25 of 44 (permalink) Old 06-17-2007, 10:57 AM Thread Starter
ThrillKill's Avatar
Quoted: 5 Post(s)
Truly appreciate your help.
Again I apologize for the pics. My kid still hasn't located my camera cable. I'm waiting till tomorrow to kill him as doing the dirty deed today would cast me in an unfavorable light.
post #26 of 44 (permalink) Old 06-17-2007, 11:26 AM Thread Starter
ThrillKill's Avatar
Quoted: 5 Post(s)
I still think this sensor is located on the outside of the car. Why would it be inside if it's purpose was to detect outside temperatures?
ie:
Your evaporator temperature sensor appears to be malfunctioning. Usually a bad evaporator temperature sensor is indicated by code B1230. Your car does not indicate this code. However, a bad evaporator sensor does not always trigger the code. The sensor reports a temperature of 129 degrees. The outside air is only 68 degrees. It's impossible for your evaporator temperature to be that much warmer than the ambient air. When the evaporator temp sensor reports a value like this (and nothing else is out of spec), your A/C should run for 10 minutes after starting the car and then automatically switch off. It does this is to protect the evaporator from freeze damage. The climate control system carefully regulates the evaporator temperature to make sure it does not drop below 33 degrees. If the temperature drops below 33, the moisture in the air may freeze and damage the evaporator. When the temperature sensor stops working correctly, the climate control system cannot tell whether the evaporator is too cold. It then shuts off to protect the system.'
Code B1227 Explanation: This sensor measures the temperature outside your car. It is reporting an implausible temperature
post #27 of 44 (permalink) Old 06-17-2007, 11:39 AM Thread Starter
ThrillKill's Avatar
Quoted: 5 Post(s)
FWIW
I also did a visual inspection of the compressor and it is indeed engaging and disengaging by pressing the EC button so I don't think it's the compressor. Furthermore I disassembled the duo-valve and it seems to be clean and in great condition.
post #28 of 44 (permalink) Old 06-17-2007, 11:47 AM Thread Starter
ThrillKill's Avatar
Quoted: 5 Post(s)
This from TresX on another forum:
AHA!!!! THERE YOU GO!!! There's the problem. Your evap. temp sensor is reading 126 degrees!!!! Unless it's REALLY hot where you are, it is BAD The value for #5 should be ambient temperature OR a temperature SIGNIFICANTLY LOWER than ambient temp. when the AC is on. In fact, if you check the car in the morning (before you turn it on), the value for #2 should be the same as #5. #2 is outside air temperature value. If they aren't the same, and 2 seems right and 5 is WAY off.....Go to the stealership...get yourself an evaporator temperature sensor and swap it out. It is located under the driver footwell along the firewall. You won't be able to see it without a flash-light and will still be a little hard for you to find when you do have one. (the replacement part is slightly different looking from the original.
I assumed he meant the outside of the car as you cannot see the firewall from the inside.
post #29 of 44 (permalink) Old 06-17-2007, 12:39 PM
Quoted: 4 Post(s)
ok you are still mixing up the evap sensor and the ambient temp sensor. the evap sensor is located next to the evaporator (hense called evap temp sensor), its purpose is to measure the temp at the evaporator and report it to the aac control panel. basically like mentioned above, if the temp at the evaporator gets too low, it will cut of the ac as to prevent damage to the evaporator.
now the ambient temp sensor reports the outside air temp to the aac control panel.
so if the evap sensor is responsible for measuring the evap temp, why would it be on the outside of the vehicle????
now the evap sensor is NOT located on the outside of the car. i have replaced many of these before, I am a Benz tech, the evap sensor is the same on all MB models and is in the same place, sticking into the heater housing where it measures the evap temp.
now look up to the right into the heater housing, you should see it sticking into the housing. if this si still an issue, let me know
post #30 of 44 (permalink) Old 06-17-2007, 12:46 PM Thread Starter
ThrillKill's Avatar
Quoted: 5 Post(s)
Could you please draw an arrow on my picture? I don't know a heater housing from low income housing and I swear I've been out to the garage 36 times with a very bright work light and I cannot see it or anything that remotely looks like it.
    Where is the temperature sensor? jalvarez W203 C-Class 3 12-19-2006 08:52 PM
    A/C Evaporator Temp Sensor Jonas_Gothenburg R170 SLK-Class 10 08-07-2006 10:06 AM
    A/C PROBLEM EVAPORATOR TEMP SENSOR? 93 BENZ S400SEL W140 S-Class 2 09-20-2005 06:54 PM
    Outside Temperature Sensor acmerocksusa W124 E,CE,D,TD Class 1 12-28-2004 09:07 PM
    Outside Temperature Sensor kaminski W202 C36 AMG, C43 AMG 2 05-18-2003 04:43 AM
