Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 06-12-2007, 07:45 PM   #1 (permalink)
Date registered: Jun 2007
HELP! with a C280 engine problem
I have a `97 C280 that has been problem free...until now....it just cuts out for no reason. After cutting out (stalling) sometimes it will start and sometimes it wont. There are NO OBD codes to be read and no warning lights are on. Fuel pressure has been checked and is ok...anyone please help me with this? Any ideas or suggestions?
dbellos is offline   Reply With Quote
Old 06-12-2007, 09:46 PM   #2 (permalink)
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: CLK430
Sounds like a faulty crankshaft position sensor (CPS).
MarcusF is offline   Reply With Quote
Old 06-13-2007, 01:27 PM   #3 (permalink)
cps response
wouldnt there be a code if the cps was bad?
Old 06-13-2007, 01:28 PM   #4 (permalink)
Old 06-13-2007, 01:42 PM   #5 (permalink)
MarcusF's Avatar
Vehicle: CLK430
Nope, the engine simply stops running.
Old 06-13-2007, 05:03 PM   #6 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, dbellow, welcome to the forum.
As marcusF so wisely states, there is NO CODE for a faulty CPS.
Codes and CELs return only for things that affect emissions, CPS faults don't do that.
You have the classic symptoms for a defective CPS, so that's where I'd first look. Not a bad DIY job if you're handy, not horribly expensive even at the shop since it's pretty quick. The danger is when they want to charge you a couple hours diagnostic time, that will cost more than the silly sensor and it's installation. In your shoes if I wasn't going to DIY I'd just tell them to change it, 90% chance that will fix it, otherwise you'll get stuck with diagnostics anyway.
Fill out your profile as you have time and as a rule of thumb, if you have a question about your model car, it's best to post it in your native specific forum (W202) and not this general one.
Take care and enjoy the ride,
Greg
Meister Eckhart
95- c280 Problem/HELP PLEASE snoopdouggydoug General Mercedes-Benz 3 01-04-2008 04:01 PM
C280 Problem, Please Help. helpme_to_helpyou General Mercedes-Benz 2 06-05-2007 02:06 PM
WTB 95 C280 engine plastic cover? Toward frnt of engine Black Plastic with Bnz logo. Bryan858 For Sale, Trade & Wanted Items 0 01-08-2007 10:33 PM
Changing a c280 engine 2 a c43 engine is this possible? crazydog4424 W202 C-Class 1 01-16-2004 09:43 PM
where did MB get the C280 engine from? Guest (MBNZ) W202 C-Class 4 07-08-2001 10:40 AM
