Paint, Leather and Trim Restoration Recommendations - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-12-2007, 11:01 AM Thread Starter
Date registered: Jun 2007
I recently purchased an 1981 300SD that has an excellent body and chrome exterior. The dark brown paint is faded and slightly spotty darker spots (small 1/8 to 1/4") . I have done a little research about polishes and am wondering if this paint is metallic or if it has been clear coated?
Any recomendations on polishes and waxes that would help restore the paint to a more brilliant finish?
Chrome polish?
What is the best way to restore cracks in the dash and seats?
Small tears in the leather?
Good place to find trim pieces like a new center consol wood panel etc.?
Thanks for the help.
Great forum!
greenguru is offline
post #2 of 4 (permalink) Old 06-12-2007, 11:04 AM
slybydesign's Avatar
Date registered: Jan 2007
Vehicle: My Two Left Feet
Greenguru, have you posted your questions in the Detailing section of this forum. They have alot of great resources on detailing plus they have the Grots detailing manual PDF download for free. Good luck.
slybydesign is offline
post #3 of 4 (permalink) Old 06-12-2007, 11:11 AM Thread Starter
Will definately check it out. I am still new to the forum, figuring it all out.
post #4 of 4 (permalink) Old 06-12-2007, 11:13 AM
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
Quoted: 2 Post(s)
You will want to post your questions down in the W126 forum which has many folks that have expertise in most of the questions you asked.
Also you might want to fill out your profile so folks will know where you are. That way we might be able to recommend an expert that is right in your area.
Generally, I would recommend that look at getting replacement skins for the leather seats if they are torn. Products like Leatherique CAN work but requires a deft touch to do correctly.
For your dash, I believe that Perfomance Products has a dash cap that fits over the current dash that will take care of the cracks that nearly everyone has on their car. If you try and find a used one, it will most likely have the cracks also and you will be in for a 15-25 hour remove-replacement job [if all goes well]. They fit well and are a good improvement over the cracks. They will also have console trim pieces. Get their catalog.
For chrome polish, I use Mother's. It is available at nearly any auto store in America and used with either a buffer or by hand, it will work. Make sure you are polishing chrome and not chromed plastic which has a coating on it. Buffing that will take the coating off.
As for the paint, check and see who your local Benz dealer uses for their body shop. Have their body shop service writer look over your car and give you an estimate to repaint. You will learn a lot from that 30 minute walk around with the guy. Ask questions, they usually are more than happy to provide suggestions on whether a full paint job is required or if a color sand or just a buff out would bring back the original [or close] luster.
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline
    Leather inserts vs. Leather Trim: What's the difference? Pics? modulated W211 E-Class 8 01-16-2010 11:14 AM
    Leather and trim paint 142 TPL R170 SLK-Class 0 05-29-2007 12:28 PM
    Anodized window trim restoration AzimuthAviation W126 S,SE,SEC,SEL,SD,SDL Class 14 10-19-2006 03:09 PM
    Leather Restoration Manual Kirill R170 SLK-Class 0 03-30-2005 07:30 AM
    280SL wood trim restoration Guest (MBNZ) General Mercedes-Benz 1 10-21-2000 05:07 PM
