Raising the car: axlestands or ramps? - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 06-03-2007, 03:45 AM Thread Starter
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 405 Post(s)
When you need to get under your car, are you OK with jacking up the car and using a pair of axlestands? And where precisely do you set them?
Or do you feel safer running it up a set of ramps?
keyhole is online now
post #2 of 17 (permalink) Old 06-03-2007, 08:27 AM
Kajtek1's Avatar
Quoted: 1291 Post(s)
Ramps all the way. Much easier and much safer. I have HD ramps for pickups, that are taller than standard. On some MB models I need to put a plank at the bottom to avoid scratching bumpers when driving on it.
Kajtek1 is offline
post #3 of 17 (permalink) Old 06-03-2007, 08:56 AM
Date registered: Dec 2006
Ramp definately.
funnyguy1 is offline
post #4 of 17 (permalink) Old 06-03-2007, 12:11 PM
Date registered: Oct 2006
Axle stands definitely.
On my W124 there are 4 good solid points to fit axle stands under.
If you use ramps then effectively you can't do any brake or suspension work.
Dave!
M119Howitzer is offline
post #5 of 17 (permalink) Old 06-03-2007, 08:25 PM
ProV1x's Avatar
Date registered: Jul 2006
Quoted: 2 Post(s)
cant be ever too cautious. use the ramps to get the car up, then place the jackstands for double protection
u dont wanna be 'that guy' that was crushed under the car..!
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline
post #6 of 17 (permalink) Old 06-04-2007, 12:15 AM
How do you go about brake and suspension work though or any work where you need to turn the steering?
If you fit them properly, axle stands are perfectly safe.
On the 124 (Not sure how the jacking points are on other Mercs) the jacking points are large nipples, if you have stands witha small cup in them then apart from being underneath and pulling ona bolt with a few tons of force, you'll never shift it.
Dave!
post #7 of 17 (permalink) Old 06-04-2007, 06:20 AM
Bogie's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML 500, 1994 Ford Explorer donated to Doctors without Borders
I never crawl under my truck when it's in the air. It's just my rule. If I had to, I suppose the ramp would be my choice. I found a teaching shop that has bays you can rent. You can even use their tools (I prefer my own) and ask the guru guy if you need advice. Not a bad deal at all.
Bogie is offline
post #8 of 17 (permalink) Old 06-04-2007, 06:42 AM
ProV1x's Avatar
Quoted: 2 Post(s)
my sears 3ton jackstands are useless with MBs b/c the jacks do not fit the rubber nipples.
for simple oil changes etc, this is what i do. i use rhino 12000lb ramps, get the car up, confirm secure mount, engage parking brake, & place chokes on both rear wheels.
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline
post #9 of 17 (permalink) Old 06-04-2007, 06:56 AM
Bogie's Avatar
You change the oil without the car being level? How does that work?
Bogie is offline
post #10 of 17 (permalink) Old 06-04-2007, 03:54 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
Use both. If you are going out to get some jack stands get the kind that have a pin than insert as oppose to the lever that locks it in place. Recently there was a thread on another forum showing a member whose jack stands failed while he was under it. His Porsche 914 came down on his face. You can never be too careful when you are under a vehicle.
Mike
Michael Pillay is offline
Loading ramps for the Sprinter van Guest (MBNZ) W901-905 Sprinter 3 01-07-2013 06:14 AM
Ok to use ramps to raise e320, recommendations? 87path W210 E-Class 35 08-26-2009 03:23 PM
oil change on ramps? andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 3 05-09-2006 09:51 PM
RV ramps that work with AMG bumper fgwinn R171 SLK-Class 0 04-24-2005 12:16 PM
Will Ramps Work? donwuan W140 S-Class 7 04-07-2005 10:19 AM
