300d wont turn off - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-02-2007, 04:44 PM Thread Starter
Date registered: Jun 2007
Vehicle: 1983 300d
300d wont turn off
I just got my first benz. it is a 1983 300d I have to open the hood and push a lever to make the car turn off sometimes. what is usually wrong when this occurs
keimini is offline
post #2 of 5 (permalink) Old 06-02-2007, 05:28 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
Its been a while, the basic system has a vacuum operated valve that does the same thing you do when you push the stop button. You have to track it down to the ign switch or the vacuum element and things in between.
Peter Guenther is offline
post #3 of 5 (permalink) Old 06-02-2007, 08:11 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 712 Post(s)
Very common problem, usually caused by a vacuum leak or a shut-off valve failure.
GeeS is offline
post #4 of 5 (permalink) Old 06-02-2007, 10:21 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Most of the time the vacuum lines got pulled from fittings. Check in the oil filter area. There is bunch of fittings there and they got pulled easily by "mechanic" changing the filter.
If all the lines under the hood look good, the leak is probably on the door locks. Plug the tubing going behind firewall to separate that.
Kajtek1 is offline
post #5 of 5 (permalink) Old 06-03-2007, 08:37 PM
Date registered: May 2004
Vehicle: 300SD
Get yourself a mightyvac (or better) vacuum tester,,, you'll love what it can do for you.
1993 400e
1987 190D
1984 6.2 suburban
2001 e320 4matic
https://benzbonz.biz/store
mespe is offline
    wont turn off keimini W123 E,CE,D,CD,TD,TE Class 2 06-02-2007 06:32 PM
    radio wont turn off? killamike415 W163 M-Class 4 01-11-2007 07:55 PM
    my turn signals wont turn off SLICKSLK007 W203 C32 AMG, C55 AMG 2 10-18-2006 06:06 PM
    Hazrads wont turn off!!!! weapon C208/A208 CLK-Class 4 01-18-2006 05:47 PM
    Help lights wont turn off samsongee C208/A208 CLK-Class 1 07-08-2004 01:54 AM
