Help with E-Class - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 05-28-2007, 05:14 PM Thread Starter
Vehicle: Mercedes E-240 2000 Approx 31000 Miles
Help with E-Class
Hi All
Just joined the boards and after some advice on my Mercedes E-240...
The problem is that sometimes (seems to be happening maybe 4-5 times a week) when I start up the car and drive off there seems to being a gear problem..
Sometimes it
1) Seems to be stuck in first gear and obviously the revs are high.
2) Seems to be stuck in first gear and then suddenly changes through the gears quickly due to the high revs
If I can safely pull the car over the solution is to turn the engine off and then restart. This has always sorted out the problem but is obviously a pain...
Any advice would be gratefully received !!!
Iceman
iceman07 is offline
post #2 of 12 (permalink) Old 05-28-2007, 05:37 PM
Kajtek1's Avatar
Quoted: 1291 Post(s)
Welcome to the forum. You don't list the year, but I assume that you have driver-adaptive transmission?
Those transmissions keep high rpm with cold engine to speed up the warming up period. If this is not the case, you might have some error codes. Get a scanner, or let the shop scan for codes.
Kajtek1 is online now
post #3 of 12 (permalink) Old 05-28-2007, 05:55 PM Thread Starter
Thanks for the quick reply..
The car is a 1999 model..
Can anyone recommend a good value scanner for mercedes cars. I'm starting to think it's going to be really useful !!
iceman07 is offline
post #4 of 12 (permalink) Old 05-28-2007, 06:21 PM
Kajtek1's Avatar
Where are you located?
In US -Autozone chain offers free scanning. I bought good scanner for $80. They get cheaper and cheaper. Now for less, than $100 you can buy one with battery backup, that will hold the readouts.
post #5 of 12 (permalink) Old 05-28-2007, 06:26 PM
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2012 C300 Sport 4Matic and 2003 CLK430 Cabrio
Quoted: 24 Post(s)
Premium Member
Cool
Iceman,
Welcome to the forum. Come hang out in the W210 forum. You will find almost any info for you car that you may need.
acarter53 is offline
post #6 of 12 (permalink) Old 05-29-2007, 12:39 AM Thread Starter
Thanks all for the advice..
I'm based in the UK..
The local mercedes dealership charge approx £115 for a scan !!
iceman07 is offline
post #7 of 12 (permalink) Old 05-29-2007, 01:41 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
have you checked your trans fluid level? a low fluid level will cause the vehicle to stay stuck in first gear. if the level is fine, possible a bad speed sensor.
Streetglower is offline
post #8 of 12 (permalink) Old 05-29-2007, 10:08 AM Thread Starter
I haven't checked the transmission fluid level so i'll start there and see how I go
Thanks Again everyone..
iceman07 is offline
post #9 of 12 (permalink) Old 05-29-2007, 10:17 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Iceman, and welcome to the forum.
I'm a fellow 210 driver, if you're posting about your model specifically it's always best to post in your car's native forum instead of this general one.
You didn't mention the mileage on your car, but I'd guess you're past-due for an AT fluid and filter change. Those are pretty typical symptoms of degraded fluid/clogged filter media.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #10 of 12 (permalink) Old 05-29-2007, 11:22 AM Thread Starter
Hi Greg
Thanks for the welcome and sorry about posting in the wrong forum....I'll claim the newbie defence
The car has only done 32000 miles but from everyone's comment a AT fluid change has got to be worth a go
Iceman
iceman07 is offline
anyone need body kit such as: Amg C43,Lorinser,Carlson for mercy C-class,A class,E class,S class,Clk Guest (MBNZ) W202 C36 AMG, C43 AMG 16 04-01-2007 02:28 PM
R-Class DVD Navigation - Comes with MY 2005 C-Class & CLK-Class DVD wiseeguy W251 R-Class 9 06-26-2006 02:49 PM
AMG S55 INSTRUMENT CLUSTERS W220 S CLASS AND W215 CL CLASS CL55 Vinbenzo W220 S-Class 0 11-15-2004 01:56 PM
Does the new rear taillights of a S-class or a CL-class fit on a c-class model sedan?? or ... BOY-6 W163 M-Class 0 05-02-2003 02:22 AM
Will the 210 (97 E-Class) 16" and the 203 (01 C-Class) 15" rims fit the 201 (87 190E - 16V)? Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 09-11-2001 06:14 PM
