Help with E-Class - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 05-29-2007, 01:55 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Originally Posted by iceman07
Hi Greg
Thanks for the welcome and sorry about posting in the wrong forum....I'll claim the newbie defence
The car has only done 32000 miles but from everyone's comment a AT fluid change has got to be worth a go
Ice, no worries with the forum preference, all the forums organize stuff differently.
Generally speaking there are so many 722.xx trannys out there that it's just as meaningful in the general forum.
You've got the 99 so you can actually do the fluid change yourself, drain the pan, pull it, drain the converter, clean the pan, swap the filter, slap it back together and refill. Not too difficult a job, but the fluid is pretty pricey (US$15/lt and you need 9, the last one goes in after a start, gear cycle and then based upon the dipstick level, I usually measure what I get out and put that much back in, then do the start/gear cycle, then add as necessary).
32,000 is low miles but I'd bet the fluid is still in pretty bad shape, driving a car very little is almost as bad as driving it a lot.
Take care and enjoy the ride,
Check Codes is offline
post #12 of 12 (permalink) Old 05-29-2007, 02:49 PM
Musikmann's Avatar
Quoted: 5 Post(s)
Agreeing with Greg here, please change your ATF and filter. After considerable debate on another thread, I became convinced that I was past due at 58,000 miles on mine. I had a laboratory perform a chemical analysis on my old fluid, and they confirmed it.
Musikmann is offline
    anyone need body kit such as: Amg C43,Lorinser,Carlson for mercy C-class,A class,E class,S class,Clk Guest (MBNZ) W202 C36 AMG, C43 AMG 16 04-01-2007 02:28 PM
    R-Class DVD Navigation - Comes with MY 2005 C-Class & CLK-Class DVD wiseeguy W251 R-Class 9 06-26-2006 02:49 PM
    AMG S55 INSTRUMENT CLUSTERS W220 S CLASS AND W215 CL CLASS CL55 Vinbenzo W220 S-Class 0 11-15-2004 01:56 PM
    Does the new rear taillights of a S-class or a CL-class fit on a c-class model sedan?? or ... BOY-6 W163 M-Class 0 05-02-2003 02:22 AM
    Will the 210 (97 E-Class) 16" and the 203 (01 C-Class) 15" rims fit the 201 (87 190E - 16V)? Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 09-11-2001 06:14 PM
