Squeaking Noise!! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-25-2007, 12:44 PM Thread Starter
Squeaking Noise!!
My 92' 400SE W140 makes a squeaking noise when i increase the RPM. It makes the noise in park, drive, reverse and neutral, it starts at around 1000RPM and gets louder as it increases to about 5,000RPM. When i rev the engine high after 5k the squeaking goes away, but then starts again at normal RPM. After doing research i found out it can be due to numerous problems...starting from the least of my worries:
- The drive belt needs adjusting...might be loose..
- The squeaking is from the low level of power steering fluid?
- The power steering pump is bad?
P.s...the noise isnt only there when i turn the steering.
If anyone has had this problem or might be able to suggest what the problem might be i would appreciate a response Thank you.
benzW140 is offline
post #2 of 2 (permalink) Old 05-25-2007, 01:59 PM
Date registered: Jan 2006
Vehicle: 00 SL500 SOLD, 05 SL600 Sport, 09 Silverado 4x4 LTZ,SOLD '15Silverado LTZ 6.2 8Speed John Deere 318
Quoted: 2 Post(s)
Tighten the belt!!!!!!!!!!
drags1998 is offline
    Squeaking Noise benzW140 W140 S-Class 2 05-26-2007 05:22 AM
    Squeaking Noise?? bcaese W163 M-Class 7 03-12-2007 08:33 PM
    Squeaking noise BBALLER14 W220 S-Class 3 06-09-2006 03:36 PM
    squeaking noise? acbenz C208/A208 CLK-Class 2 11-30-2005 03:05 PM
    190E 2.6 squeaking noise StarGazer W201 190-Class 4 10-20-2005 02:07 PM
