S 140 wont rev past 4000prm ..WHY ??after i washed engine!! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-23-2007, 07:03 AM Thread Starter
Date registered: Jul 2006
Vehicle: 1994 s320D
i washed my engine and then this happened
any ideas what i should check
should i reset the evu if so how do i do it
is it in safe mode
S3201994 is offline
post #2 of 3 (permalink) Old 05-23-2007, 07:18 AM
SSL
Date registered: Jul 2005
Vehicle: R107 300SL; 1990 500SL (R129);2001 R170 230SLK
Quoted: 9 Post(s)
is it in safe mode
S3201994,
If the car is in neutral and you are having fun with the loud pedal don`t worry.
The engine has a limiter which will stop you revving the engine beyond 4,000rpm.
If it`s happening whilst you are in gear then you have a problem and you need someone with real expertise to sort you out.
SSL is offline
post #3 of 3 (permalink) Old 05-24-2007, 05:19 AM
eric242340's Avatar
Quoted: 295 Post(s)
Diesel engines have a govenor on the injection pump and this will not allow revs beyond 4000 when in nuetral.
eric242340 is offline
    2003 ML500 wont rev just cuts out AdamNEUK W163 M-Class 8 03-03-2007 12:48 AM
    350sdl wont accelerate past 80mph ericmichael76 W126 S,SE,SEC,SEL,SD,SDL Class 2 02-24-2007 04:20 PM
    Wont rev just cuts out AdamNEUK W163 M-Class 0 02-19-2007 02:21 AM
    my 97 E420 won't rev past 5000rpm - why? ProV1x W210 E-Class 0 10-18-2006 07:41 PM
    87 300d-t will not rev past 1500 rpm's, but does not stall benhamin W124 E,CE,D,TD Class 2 12-17-2004 12:06 AM
