coincidence or flaw? - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 05-22-2007, 08:12 AM
Vehicle: Volvo 940GLE, GMC Suburban, Infiniti I30, Toyota Prius, VW GTI, MB SLK350, Lexus IS250
Originally Posted by Kajtek1
You want the job done right. . do it yourself. ....
I love to do it myself as well other than having a bad rotator cuff from cross country skiing. Since owning a diesel, I never liked changing oil. I took an A/C job to a small shop, and the guy is a crook. Should have gone to the sdealer in the first place and would had been cheaper.
Other than that, stick to some place you know. I have 7 cars and one shop gets all the oil change business (Speedy Oil Change). It has worked well so far. Only get batteries from Sears. Had a tire shop mess up parking brake switch once and told me to get a brake job. Now, most tires come from Costco. I simply left the groove in and it wore flat with time. Some good shops only do certain things. Santa Clara Wrecking is a great and honest 4x4 shop but they only work on drivetrains.
I made mistake myself also. Did a brake job on the rear drum of the Suburban and a slave cylinder plunger fell off and cut a groove in the drum.
CalifSLK is offline
post #12 of 14 (permalink) Old 05-22-2007, 11:04 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Loeber did it.
GeeS is offline
post #13 of 14 (permalink) Old 05-22-2007, 11:32 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Here's a vote for coincidence.
Musikmann is offline
post #14 of 14 (permalink) Old 05-22-2007, 11:51 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Originally Posted by Diesel Benz
I like the comments so far but would like to see some serious ones too, I mean how could they break the AC when only changing engine oil? Do -99 cars have ceramic seals, perhaps you had a season without using AC every now and then, and both cars started leaking?
DB, it's a tongue-in-cheek joke that changing the oil would result in failure of AC.
Sears service can be spotty (listen to Ron White's story about them, talk about bad labor) but you'd have to be completely inept to goof up the AC while changing oil.
Take care and enjoy the ride,
Check Codes is offline
    I'm sure it's just a coincidence...really Zeitgeist Off-Topic 5 10-09-2006 08:46 PM
    coincidence? drenc W140 S-Class 5 07-30-2006 07:11 AM
    Coincidence? MBeige W123 E,CE,D,CD,TD,TE Class 0 09-20-2004 06:11 PM
    Is this a design flaw correction? chriss W126 S,SE,SEC,SEL,SD,SDL Class 2 04-27-2003 12:16 AM
    Smartkey design flaw Guest (MBNZ) W203 C-Class 4 10-03-2001 04:05 AM
