HELP ml wont stay running... - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-21-2007, 10:37 AM Thread Starter
my 01 ml 320 starts, runs for about 3 seconds then shuts off. any ideas?
canadaml is offline
post #2 of 4 (permalink) Old 05-21-2007, 10:43 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Fuel pump/relay? Any other symptoms? Anything led up to this?
flyboyike is offline
post #3 of 4 (permalink) Old 05-21-2007, 01:27 PM Thread Starter
i pulled the fuel pump relay in the pass. kick and it functions normally. all fuses in the ml are good. after it shuts down there is the message "start error" on the display on dash. could this be an immobilizer issue? also the service indicator was on before and the ml had very poor throttle response. i would push the pedal down and not much would hapen til bout half way then it would kick in.
canadaml is offline
post #4 of 4 (permalink) Old 05-21-2007, 05:13 PM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
this usually indicates a failure of the AAM, key or das. first try your other remote and see if the issue is still there. if so that rules out the remote from being the issue. after that a quick test is needed to determine if fault codes exist. the last one I had with this issue was a faulty aam.
Streetglower is offline
    Door wont stay closed... GermanlookT3(Tom) Vintage Mercedes-Benz 5 10-13-2006 09:11 PM
    89 190e that wont stay running!! mercedesgirl W201 190-Class 2 09-26-2006 05:55 PM
    Rear seat belts wont stay snug on passengers ? MikeMc W140 S-Class 3 08-20-2006 08:42 PM
    84 300D glow plugs wont stay on xdoug92000 W123 E,CE,D,CD,TD,TE Class 3 08-12-2006 09:44 PM
    Diff lock wont stay locked Guest (MBNZ) Unimog 1 01-02-2002 08:33 PM
