"SERVICE EXCEEDED BY ****** MILES"..what does dat mean? - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 04-12-2007, 07:27 PM Thread Starter
Big Aleks's Avatar
Date registered: Apr 2007
Vehicle: C 240 02'
Send a message via AIM to Big Aleks
i bought a MB not too long ago..and it keeps saying "service A (and service B) exceeded by 9000 miles" and ish
does that mean i need to get it serviced or what?
Big Aleks is offline
post #2 of 23 (permalink) Old 04-12-2007, 07:52 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
Either it's due for a service or someone forgot to reset the service indicator. 9000 miles? It's due either way.
MarcusF is offline
post #3 of 23 (permalink) Old 04-13-2007, 06:26 AM
ProV1x's Avatar
Date registered: Jul 2006
Quoted: 2 Post(s)
it means it's time for u to bend over and let your local MB dealer a$$rape you.. sorry
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline
post #4 of 23 (permalink) Old 04-14-2007, 04:54 AM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
FYI, Service A or B is DIY job you don't have to go to the stealership. Check & read your manual for your Service A needs. Btw, welcome to the Board Alex!
Take care & enjoy the ride,
JOE55
JOE55 is online now
post #5 of 23 (permalink) Old 04-14-2007, 08:24 AM
Date registered: Aug 2005
Vehicle: 2003 S430 Sport Edition
The service is due. You can check with the dealer when was the last time the car had service and verify the mileage recorded. If so, have the car serviced and the MB tech might adjust the service intervals mileage depending in the mileage due.
Eddie
Curacao is offline
post #6 of 23 (permalink) Old 04-14-2007, 09:43 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
The car is either badly overdue for at least a oil and filter change, or it was serviced at a non MB facility and the technician did not know how to reset it. It is a countdown timer based on time , miles, and oil properties. I would only use MB filters and synthetic oil, I only let my MB dealer change the oil, since I have an extended warranty. There are some MB dealers wont reset the timer if you dont opt for the A or B "inspect" etc. The instructions are in the manual.
I had a major issue with them this week trying to sell service which they or I did recently like (plugs caps and rotors 10,000 miles agofrom them, and air filters I did less than 90 days ago)
Definately a sore subject, replace if bad, dont try and jack up the bill.
Peter Guenther is offline
post #7 of 23 (permalink) Old 04-14-2007, 03:47 PM
Jayhawk's Avatar
Vehicle: S500/W220/2000
I suspect you are way overdue for a (or b) service:
A-Service First visit at approximately 10,000 miles or 1 year, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Check warning and indicator lamps, illumination and interior lighting
· Check windshield wiper, windshield washer system, headlamp cleaning system
· Reset maintenance service counter in instrument cluster
Wheels, brakes
· Check front brake pads for lining thickness
· Check tires for damage, condition
· Correct tire inflation pressure
Engine compartment
· Change engine oil and filter
· Fluid level checks of the following:
· Engine cooling system, antifreeze and corrosion protection
· Windshield washer system
· Brake system
· Check and correct battery fluid level
· Check battery condition
· Check catch, safety catch and hinges on engine hood for proper operation
Trunk
· Correct tire inflation pressure in spare tire
B-Service
First visit at approximately 20,000 miles or one year after previous service, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Replace dust filter (not applicable to SL-Class)
· Replace combination filter (SL-Class)
· Check parking brake (function test only)
Wheels, brakes
· Check condition/thickness of front and rear brake discs
· Check front and rear brake pads for lining thickness
· Check tires for damage and condition
· Measure tread depth, record in mm
Underside of Vehicle
· Check for major components leakage
· Check for chafe marks, line routing, damaged components
· Check condition of front axle ball joints and rubber boots
· Check condition of mechanical steering components and rubber boots
Engine Compartment
· Check and replenish all fluid levels
· Check engine cooling system, antifreeze and corrosion protection
· Check brake system
· Check power steering
· Check Active Body Control
· Check windshield washer system
· Check condition of poly V-belt
Trunk
Don't believe everything you think
Jayhawk is offline
post #8 of 23 (permalink) Old 04-14-2007, 05:39 PM
asianml's Avatar
Date registered: Sep 2005
My guess is that whoever did the previous service didn't reset the FSS. The Service A and B you can do by yourself at home.
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #9 of 23 (permalink) Old 04-14-2007, 05:45 PM
Jayhawk's Avatar
Would you care to tell us exactly which of the following services YOU have preformed "at home" by yourself:
Interior
· Function check
Wheels, brakes
Engine Compartment
Trunk
Jayhawk is offline
post #10 of 23 (permalink) Old 04-14-2007, 05:48 PM
asianml's Avatar
They're all "checks" Jayhawk. They're not that hard to do.
asianml is offline
    "Yakuza" Sato's AMG Mercedes from "Black Rain" (starring Michael Douglas&Andy Garcia) JJB236 W124 E,CE,D,TD Class 23 10-05-2009 01:19 PM
    Service "A" & "B" mbz4ever W163 M-Class 6 01-21-2003 09:07 PM
    What does service "A" and "B" usually cost at a MB dealer? mikeyCLK C208/A208 CLK-Class 5 01-15-2003 02:17 PM
    320 Locked in "Park" 300 miles from a dealership! JKJ W163 M-Class 3 08-22-2002 06:24 AM
