Type Oil Question !!! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-04-2007, 04:27 PM Thread Starter
ecko121979's Avatar
Date registered: Dec 2006
Vehicle: 01' C320
Send a message via AIM to ecko121979
Im gonna have to change my oil soon in 500 miles, and i wanna buy my own oil how much do i need for my 2002 C320 ? what oil do u guys recommend or what kind do u guys usually use ? mobil1 or purple oil ??? viscosity 5W-40W, 10W-40W etc...??? i got 75000 miles on my car and i live in southern california weather temp is between 75-90 this spring.. can u guys please give me a little help, all help will be appreciated. Thanks !
ecko121979 is offline
post #2 of 2 (permalink) Old 04-04-2007, 06:49 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, ecko.
Hundreds of posts on this all over the map.
Your car holds 8 liters (8.5 US Qt) of oil.
MBZ says to use Mobil1 0W40, which meets their specification. No only the newer and harder to find 5W40 meets that spec as well. You can safely use that oil in any climate found on this planet.
Other manufacturers have other viscosity ranges that meet the spec, but you must use synthetic. If you search you'll find a link to a web page that has all the oils that meet the spec. I've never found one of them in a store besides the Mobil1 0W40.
Royal Purple does not make an oil that has been certified by MBZ for use in your car. They say it's because the market isn't big enough for them to go through the process, but they opine that their products are fine to use. Your choice, they have lots of fans.
Be sure to buy the fleece oil filter for your car, and I recommend buying the kit so you get the necessary o-rings as well. I did a pictorial DIY post for the V6 320 and it's in the 210 forum, you can probably get some pointers there if you want to take a look.
Take care and enjoy the ride,
Greg
Check Codes is offline
What type of oil is best 1976240D General Mercedes-Benz 1 12-22-2006 12:34 AM
Oil Change and oil type HyperLite W202 C-Class 3 03-20-2006 05:20 AM
Type of oil Emptydata R170 SLK-Class 19 07-13-2005 05:04 AM
oil type? SLKRoadster99 R170 SLK-Class 12 05-09-2005 08:34 PM
Type of Oil? Nic (Sweden) R170 SLK-Class 11 10-26-2001 03:22 PM
