What to do when garage door opener is lost. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-02-2007, 08:43 PM Thread Starter
Tachyon's Avatar
Date registered: Feb 2007
Vehicle: BMW
Exclamation What to do when garage door opener is lost.
Hey everyone,
I didn't post this in OT because I don't have privileges there, yet (due to post count I believe). I have a Craftsman 1/2hp garage door opener and the remote was left outside by a relative (Why you ask? I ask the same). Well, I'm assuming someone I don't know has it and I want to reset the opener. Do I just unplug it?
2001 BMW E38 740iL Sport
1984 MB W126 300SD (gone)
1991 MB W126 560SEL (gone)
Tachyon is offline
post #2 of 4 (permalink) Old 04-03-2007, 06:59 AM
GreatBenz's Avatar
Date registered: Oct 2005
Vehicle: 1995 500SL
Hope you still have the manual which should show how to set the dip switches to change the preset frequency. Since you do no longer have the remote you will need to get another compatible with the model you own - additional info might also be given on the package of the new remote to help you.
"Character is not the main thing, it is the only thing."
GreatBenz is offline
post #3 of 4 (permalink) Old 04-03-2007, 08:30 AM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
Unplug woudn't work - you have to reset the opener - call Sears\Craftsman customer service - they will tell you how to do it.
Kirill is offline
post #4 of 4 (permalink) Old 04-03-2007, 09:21 AM
Date registered: Nov 2006
Vehicle: '04 SL 500, '03 BMW M5, '03 BMW 325i,
What you should do depends on the model of the opener. Some are rolling codes and all you need to do is program the existing openers in enough times to "push" the old code out. Older openers have the dip switches as described earlier. If you wanted to upgrade the receiver, do as I did. Purchase a new receiver with 2 remotes and you're set. Ran me about $70. I also did this so I could use the homelink option in the car. It works very well and is secure because the homelink only works when the key is in the ignition.
dragoncoach is offline
    Garage door opener ldk5 R129 SL-Class 7 06-18-2009 07:27 PM
    Garage door opener? Corsino R171 SLK-Class 7 12-19-2005 06:38 AM
    Garage Door Opener dinkoslk R171 SLK-Class 12 10-25-2005 12:22 AM
    Built in Garage door opener and rolling code garage doors aquascape R171 SLK-Class 12 01-27-2005 04:41 PM
    garage door opener ... Arabian Knights C208/A208 CLK-Class 6 01-06-2005 12:31 PM
