ABS and SRS lights came on - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-02-2007, 12:00 PM Thread Starter
Date registered: Nov 2006
Vehicle: 1992 400e, 1992 190E 2.6
I have a 1992 400e and after my car needed a jump start (left the lights on) both the ABS and SRS warning lights came on. Any ideas????
halecuda is offline
post #2 of 4 (permalink) Old 04-02-2007, 12:46 PM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
you need to replace your battery- if the battery voltage was dropping down under 10 volts at times which is the threshold for the ESP/BAS system according to the Owners Manual.
JOE55 is offline
post #3 of 4 (permalink) Old 04-02-2007, 01:46 PM
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 10 Post(s)
Either replace that battery or have that battery checked out. If it happens again with a known good battery, it is either the alternator or voltage regulator (charging system).
loubapache is offline
post #4 of 4 (permalink) Old 04-02-2007, 10:06 PM
Diesel Benz's Avatar
Quoted: 32 Post(s)
Well halecuda mentioned he had left lights on. I don't think a battery needs to have any problem if it dies after lights being on long enough (as long as it gets properly charged after it went flat)? Wasn't the question more about clearing ABS and SRS warning lights?
Did you search for the SRS and ABS warning light posts, an answer could already have been given.
Diesel Benz is offline
    abs / srs light goes on intermittently lazuli W124 E,CE,D,TD Class 10 04-30-2009 01:22 AM
    ABS & SRS Light is on. moremercedesthanu W140 S-Class 2 01-12-2008 02:33 PM
    ABS and SRS lights came on - car will not start Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 12 11-22-2007 07:49 AM
    Abs/srs royvan R129 SL-Class 3 03-27-2007 09:59 AM
    BAS-SRS-ABS Alert dnewman W210 E-Class 7 09-06-2005 07:35 AM
