knowledge base :How to changer a Blower fan and regulator - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-27-2007, 03:54 PM Thread Starter
Date registered: Jul 2006
Vehicle: 1994 s320D
Talking knowledge base :How to changer a Blower fan and regulator
hello all thought i would add this as brett helped me out on advice for removing my ac rad
this is write up on how to change the above
you will need a Philips driver
a range of hex bits
1. open the bonnet to its 90 degree angle
2.undo the 3 Philips driver screws on the plastic water retaining bit (in the picture its removed )
3.undo the other 3-4 screws holding this piece in place
4.now you will see a filter on your right hand side remove it and you will see the blower motor +reg http://www.benzworld.org/forums/atta...1&d=1175035785
5.now look at this picture and undo the hex bolds (circled red) i used a Hitachi wh120m2 super impact 12 drill its an amazing drill btw the best i have ever used and it took me under 1 min to undo all the hex's
6.unplug the reg circled purple
7.now pull it upwards and towards you and move it side to side and it will come out
i need help wiring up my stereo can someone please tell me how and what the wire codes are ????
ID:	122180   Click image for larger version
ID:	122181   Click image for larger version
Name:	fan empty.jpg
S3201994 is offline
voltage @ blower motor is 2.8v with fan @ full speed - regulator going bad? snik W140 S-Class 3 09-18-2007 10:55 AM
knowledge base :How to remove gauge cluster S3201994 W140 S-Class 1 12-06-2006 04:38 PM
Fuel filter change DIY added to the knowledge base Brett San Diego W140 S-Class 0 11-20-2006 09:00 AM
WTB: Blower fan regulator for W210 247hoopsfan For Sale/Wanted/Trade/Giveaway 0 05-19-2006 03:30 PM
Changing the V12's front main seal posted in the "knowledge base" thread. Brett San Diego W140 S-Class 4 09-12-2005 08:57 AM
