1984 380SE Engine Seized maybe? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-12-2007, 11:57 PM Thread Starter
Date registered: Mar 2007
I returned home from a trip to the Uk after a month. My Mercedes was running great before i left. When i tried to start it. battery was very weak and barely turning over , but was turning over. I charged it to a full charge and then when turning the key , it just went to a click, I replaced the battery. Still the same. I had a shop put in a new starter. still the same. He then removed the plugs , which looked fine and tried turning the engine . it appears seized. No heat problems. recently had an oil change and the oil is very new. Its an automatic. an ideas on what to do next besides use it as an anchor
dharmaband is offline
post #2 of 4 (permalink) Old 03-13-2007, 02:26 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
can you turn the engine over by hand? if so, its not locked up.
Streetglower is offline
post #3 of 4 (permalink) Old 03-20-2007, 04:49 AM Thread Starter
no, he tried with a socket on the front of the engine and had no luck moving it. could a bearing have slipped maybe that you can get to with the oil pan off?
post #4 of 4 (permalink) Old 03-20-2007, 05:23 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
This is a long shot, The technical editor of the STAR a mercedes club magazine recounted on what tey thought was a seized engine they could not get it to turn. It turned out that the alternator had locked up. I cant immagine an engine locking up when not running. I also thought it might be a locked up starter but you said it was replaced. If you had all the plugs out it cant be a Hydraulic (fluid leaking into a cylinder)
Peter Guenther is offline
    Is my engine seized? 1986 560SEL element2012 W126 S,SE,SEC,SEL,SD,SDL Class 10 12-22-2006 03:58 PM
    FS: 1984 380SE - Yonkers, NY frankie m For Sale/Wanted/Trade/Giveaway 2 08-31-2006 07:57 PM
    Engine seized help! Heav-e-d W201 190-Class 0 02-15-2006 12:48 PM
    Rotate a seized engine 70' 280 S Rales Vintage Mercedes-Benz 3 01-20-2005 08:35 PM
    1984 380SE Inexpensive--Look jim16671836 W126 S,SE,SEC,SEL,SD,SDL Class 0 06-23-2003 06:34 PM
