Inertia switch - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-12-2007, 03:33 PM Thread Starter
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
Inertia switch
On previous cars (eg. 1990s Toyota and Ford) I have known about an inertia, or gravity switch designed to trip the fuel pump should the car get a sharp jolt - as in a crash. This was a safety feature to prevent the car bursting into flames if the fuel pump continued to run following an accident. Sometimes this inertia switch could be inadvertently tripped when parking carelessly, so it was necessary to know how to reset it. It was generally in the boot under the spare wheel, and just needed to be pressed to reset it.
My question is: Do MB cars have such an electro-mechanical feature, as I can find nothing about it in my Owners Handbook?
keyhole is offline
post #2 of 5 (permalink) Old 03-12-2007, 07:09 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Mercs have the appropriate safety device.
Not user resettable--see dealer.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 5 (permalink) Old 03-12-2007, 08:48 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
Many cars with Bosch fuel injection (or a derivative) have a device called a mass airflow sensor. Mass airflow sensors are used to determine engine air intake. When the ECU determines the engine is no longer ingesting air, it stops the fuel pump. Which model Toyotas and Fords had the inertia switch?
MarcusF is offline
post #4 of 5 (permalink) Old 03-12-2007, 11:24 PM
Kajtek1's Avatar
Quoted: 1168 Post(s)
One of the famous "safety device" is inertia switch, that unlocks the doors in case of accident.
All it takes the thieves is a sledge hammer and knowledge of the switch location. ....
Kajtek1 is offline
post #5 of 5 (permalink) Old 03-13-2007, 04:56 AM Thread Starter
keyhole's Avatar
Quoted: 375 Post(s)
Hi. This is from the UK. There was one in the boot (trunk) of my 1998 Celica which was resettable. And there was a similar switch in my 1990 Ford Mondeo.
In fact this car was once stolen from a public carpark and used to rob a Post Office. It was recovered about an hour later. I checked it out with the cops, and we found that the enertia switch had it's wires snipped. The cops told me that this was a common trick used by these guys so that the car would keep running - even if they side-swiped other cars during their getaway!
keyhole is offline
    What's this switch do? smack R/C107 SL/SLC Class 6 11-15-2006 03:08 PM
    CRIKEYS !!!...What's this switch for ?...Mystery Switch blitzgritz W123 E,CE,D,CD,TD,TE Class 7 03-20-2006 12:02 PM
    hazard switch/seat switch kickboxer W126 S,SE,SEC,SEL,SD,SDL Class 1 02-04-2006 06:35 PM
    no power to roof switch + roll bar switch ELV R129 SL-Class 0 07-03-2005 03:37 AM
    I would like to replace my speaker fader switch with a door lock switch but… barbus W123 E,CE,D,CD,TD,TE Class 1 01-25-2005 08:05 AM
