Power Seat won't go all the way back ?! - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 03-12-2007, 01:10 PM Thread Starter
Date registered: Feb 2007
The power seat on my C320 isn't going all the way back anymore. The seat position stops about 4 inches from it's furtherest setting and i hear a single click after it stops. All the other functions still work and it still moves forward and back to the stopping point..
I think it's because I had a luggage back there once and when I tried to move the seat back it wouldn't go back anymore and that somehow jammed the seat and computer, but I don't see how that could've jammed it, maybe it's a computer issue? I examined the gears on the bottom and nothing seems to be blocking it. I also unhooked the negative lead to the battery for a full day to try and reset something or anything and that also didn't work.
Any help would be appreciated! Thanks!
ucberic is offline
post #2 of 8 (permalink) Old 03-12-2007, 05:44 PM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
try moving the seat forward all the way then try moving it backwards again- it should work
JOE55 is offline
post #3 of 8 (permalink) Old 03-12-2007, 07:26 PM
Musikmann's Avatar
Quoted: 6 Post(s)
JOE55 is probably correct, but I read about a similar problem on here and a guy answered that a click(s) meant messed-up teeth somehow in the gearing mechanism.
Good Luck!
Musikmann is offline
post #4 of 8 (permalink) Old 03-26-2007, 07:49 PM Thread Starter
still no luck... damn seat. i guess it's time to take it in next month. any other suggestions? =)
ucberic is offline
post #5 of 8 (permalink) Old 03-26-2007, 09:47 PM
Kajtek1's Avatar
Quoted: 1248 Post(s)
You wouldn't be the first one with some coins jammed in the seat mechanisms
Kajtek1 is offline
post #6 of 8 (permalink) Old 03-27-2007, 06:20 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Good idea Kajtek1! Coins are constantly falling out of my side pants pocket too. Maybe I have been lucky because the driver's seat works properly for me.
post #7 of 8 (permalink) Old 03-27-2007, 07:08 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Is it a sedan or a wagon? There was a thread telling that the power seat does not go fully back if the rear seat is not properly at its normal position. A switch detecting that, if the seat is properly set, the switch may be the issue.
Don't have a wagon myself and then no personal experience. Not sure if the same happens on a sedan with load-through back seats.
Diesel Benz is offline
post #8 of 8 (permalink) Old 03-27-2007, 10:27 AM
chinny4290's Avatar
Date registered: Aug 2005
Vehicle: '94 E320 Coupe W124 (RIP) - '75 280S W116 - '11 Honda Accord Coupe V6 6-Spd (DD)
Might be his luck and he could find his old wad of $100s in a money clip blocking the gears.
chinny4290 is offline
    Power Seat won't go all the way back ucberic W203 C-Class 6 03-08-2007 03:03 PM
    Move the seat back, Waaaaayyyyy back TimsSLK350 R171 SLK-Class 1 11-04-2005 01:24 AM
    124 non-power seat to power seat swap Locry W124 E,CE,D,TD Class 0 07-12-2005 11:52 PM
    Seat back release--Released from seat itself phoenix44 W163 M-Class 1 12-19-2004 10:14 PM
    Does the rear seat seat-back recline? Thanks. MikeT W163 M-Class 5 11-18-2001 06:10 AM
