6k miles and check engine/oil light didn't go on yet... - Mercedes-Benz Forum
post #1 of 27 (permalink) Old 03-07-2007, 04:13 PM Thread Starter
Date registered: Jul 2006
Vehicle: 2003 Mercedes CLK320
Quoted: 2 Post(s)
I have an 03 CLK320 . I got it from the dealer and already drove 6k miles on it.
Will it automatically tell me when I'm supposed to do an oil change or should I just do it every so many miles?
jackie100 is offline
post #2 of 27 (permalink) Old 03-07-2007, 04:39 PM
asianml's Avatar
Date registered: Sep 2005
There should be a count down in the FSS display from 10,000 miles down to 0. 10,000 miles is the regular interval for oil changes. You should call the dealer and ask them when the oil was last changed since it's possible the FSS was not reset after the last oil change. So what you see in the instrument cluster may not truly reflect it.
Search the forum too for more information.
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #3 of 27 (permalink) Old 03-07-2007, 04:44 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
I think the default is 10,000 miles or one year. You should be able to scroll thru your menus, and find the service menu. It counts down and will alert you, when MB was providing this for free they used the count down. You can change the oil/filter at any time, but I would not do it before 7,500, and definately not go over one year.
My dealer is pretty competitive, as long as you dont give them a free reign. The A and B recommended services are a lot of check this and that, you can change air filters, wiper blades, your tires, and some other things. It will be more important as your car ages to have some services ( fluids, brakes, trans, cooling) done!
Peter Guenther is offline
post #4 of 27 (permalink) Old 03-07-2007, 04:48 PM
Musikmann's Avatar
Quoted: 6 Post(s)
You should get familiar with your steering wheel controls, and this is as good a reason as any for you to scroll through the menu. For example, there is a way that the car measures your oil level among them. However, just to be on the safe side, you should still check oil level with your dipstick every so often too.
Musikmann is offline
post #5 of 27 (permalink) Old 03-07-2007, 05:43 PM Thread Starter
Quoted: 2 Post(s)
Thanks a lot for all your help! For some reason I thought you were supposed to do oil changes every 3k miles or so, I didn't know it was 10k... Thanks
post #6 of 27 (permalink) Old 03-07-2007, 05:45 PM Thread Starter
Quoted: 2 Post(s)
Mine doesn't work properly for some reason, I forgot what it says when I try to look at the oil level, I think it said the engine has to be turned off or something, I couldn't get it to measure my oil level.
post #7 of 27 (permalink) Old 03-07-2007, 05:59 PM
asianml's Avatar
The car uses full synthetic oil. Remember that. It's very important that you use fully synthetic oil. If you have a service manual, it should list right there the acceptable oil brand and weights for your car. I personally use Mobil1 0W-40. That's what the MB dealers used to use too. However I think they've switched to a different weight. It's safe to go up to 10,000 miles. No need to change it at 3,000 miles.
Also check out Mercedes-Benz Engine Oil Recommendations if you don't have a service booklet.
asianml is offline
post #8 of 27 (permalink) Old 03-07-2007, 06:00 PM
asianml's Avatar
The car has to be off in order to test it if I recall correctly. I think there's also a dipstick in the engine bay to visually check it yourself as Musikmann suggested.
asianml is offline
post #9 of 27 (permalink) Old 03-07-2007, 06:15 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Not a problem, and that is correct. It will prompt you that the car must be level for that to be accurate; plus that the engine has to be off, and the key in the ignition switch in the last position before the start/crank one.
Some cars do have to have their oil changed every 3000 miles (I have 2 of those) but the Mercedes are different. As asianML said, use fully synthetic oil - Mercedes recommends Mobil1. They recently changed the preferred weight to 5W40 from the previous 0W40.
One last thing: don't be alarmed if your engine uses oil between changes. I bought mine used at 52,000 miles, and at 58,000, the car told me to add 2 quarts. Sad to say, that this is normal, at least for the 320 engines that you and I both have.
post #10 of 27 (permalink) Old 03-07-2007, 06:16 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
Jackie - you may not have a dipstick. My 2004 CLK does not have one.
You can flip through the Instrment cluster displays to find the right page. As you said it will not give a readout unless the car is
a) level, b) oil is hot, c) engine is off. d) oil has had time to drain
So you can only do this when you finish a ride.
Park on the level. Turn off the engine. Return in 5 minutes and turn the ignition to position 1.
Now the display will advise on your oil level. (OK, or add xx litres)
keyhole is offline
    83 Miles....Check Engine Light jakepratt R171 SLK-Class 9 12-09-2004 01:10 AM
    Check engine light came on at 4,210 miles.....what????? itswindee R170 SLK-Class 11 10-15-2004 11:52 AM
    Check engine light at 290 miles!! rkonster W163 M-Class 6 08-23-2004 11:02 PM
    4k miles and this morning, the CHECK ENGINE light went on... elfkonig W163 M-Class 14 05-03-2003 01:07 AM
    Um..... My check engine light went on at 30,050 Miles is that normal? D42 W163 M-Class 9 07-10-2002 05:06 AM
