OIl change C320 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-06-2007, 06:38 PM Thread Starter
Date registered: Mar 2007
Post OIl change C320
Ok I got a 2002 Benz C320 I bought and it needs a oil change the light is on ,So here are my guestion there is no dip stick on the engine so how much do I put in and how do I reset the oil light Can anyone HElp ME
Ledfoot02 is offline
post #2 of 5 (permalink) Old 03-07-2007, 04:17 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Owner's manual covers resetting the light. It likely covers your other questions too, but I'll defer to other owners to answer those.
sokoloff is offline
post #3 of 5 (permalink) Old 03-07-2007, 05:44 AM
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
Click onto the SEDAN portion of this Forum
Check out Do It Yourself/DIY
Change Your Own Oil
VERY INFORMATIVE. Replete with pictures!
You'll need 6 quarts of Full Synthetic Oil
New Oil Filter with O-Ring Gasket
Resetting your FSS is simple but you do need to read your Owners Manual.
I can't recall it off the top of my head.
Its REAL EASY to change your Oil
Good Luck
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
post #4 of 5 (permalink) Old 03-07-2007, 11:34 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Also, I think your car is new enough that the owner's manual should be on the MBUSA.com site in downloadable .pdf format. Go to the owner's online section and you should see a link to it.
Musikmann is offline
post #5 of 5 (permalink) Old 04-01-2010, 06:33 AM
Date registered: Dec 2008
Vehicle: 2001 C320
C320 FSS Reset / Oil Change tidbits
Resetting the FSS indicator is a breeze on my 2001 C320; oil changes are a bit trickier. First, FSS resets:
1.) Turn key to 2nd position (two turns to right just before going all the way to start engine).
2.) Use steering wheel toggle switch to get to the the FSS screen to show on instrument panel.
3.) Push in, hold, and turn to the right - all at the same time, the round mileage reset knob located on the left side of the instrument panel next to the tachometer.
4.) Answer "yes" to the "do you want to reset" question by using steering wheel toggle. The A or B service indicator will then reset and say service is due in 10,000 miles, but that will adjust accordingly as you drive (may require service less than 10k for hard / city driving; more than 10k for easy / high highway miles driving).
The C320 has no oil (or transmission) dipsticks so I suggest going to a dealer for fluid changes unless you're an expert. I had two different mom-n-pop foreign car service companies screw up first an oil change then a transmissioon fluid flush. I took it to a dealer and they rectified the problem because they have the correct (electronic) equipment to ensure the correct volume (and level) of fluid is in the vehicle. Good Luck!
airwick is offline
    Just did my Oil change & air filter change. What else does Service B entail? RaleighMB W210 E-Class 5 03-07-2009 06:39 PM
    C320 2001 Oil Change? jhartmac W203 C-Class 1 10-11-2006 09:35 AM
    Oil change for 2005 C320 PullOver W203 C-Class 3 05-22-2006 02:40 PM
    C320 W203 Oil Change Question Help WaveyKat W203 C-Class 9 10-21-2005 02:40 PM
    C320 oil change Guest (MBNZ) W203 C-Class 8 06-12-2001 04:38 PM
